[mapguide-users] New King.Oracle 0.8 - improved performance
Jonio, Dennis (Aviation) DJonio at miami-airport.com
Wed Nov 19 14:03:21 EST 2008
Haris,
>From the Event Viewer:
Faulting application mgserver.exe, version 2.0.2.3011, faulting module
KingOracleOverrides.dll, version 0.8.0.0, fault address 0x00006129.
StackTrace:
  - MgMappingUtil.StylizeLayers line 786 file
d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services
\mapping\MappingUtil.cpp          Failed to stylize layer:
LayerDefinition0
An unclassified exception occurred.
<2008-11-19T13:53:07> Fusion Viewer    10.14.12.190     Administrator
 Error: Failed to stylize layer: LayerDefinition0
r,
dennis
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Haris
Kurtagic
Sent: Wednesday, November 19, 2008 1:01 PM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] New King.Oracle 0.8 - improved performance
Sounds very strange, you are able to render that same data with other
tools ?
I tested provider with sheboygan sample data and couple of other data
sets I have and it looked ok.
Haris
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jonio,
Dennis (Aviation)
Sent: Wednesday, November 19, 2008 6:29 PM
Haris,
I followed Dave's and your suggestions. Finally got two(2) geoms to
render (out of 26000+). I am in shock. If I PAN at all everything
disappears. But if a do a Select in just the right place I get a
selection.
Geometry is rendered willy-nilly, PAN is worthless ... move 2 feet
across geoms that are hundereds' of feet in length and most disappear.
Drag a geom to the map center and it disappears. Zooming is just as bad.
I am not using that "fusion" thingee just the plain'ol frames jobbee'do.
There is something "way wrong" here. I have not a clue if it is your
issue Haris or this falls on the "dark side" :-)
R,
dennis
Kurtagic
Sent: Wednesday, November 19, 2008 11:39 AM
Yes, I would guess it is wrong extent in layer preview.
As Dave suggested set manually extents in the map and try it.
Haris
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Dave Wilson
Sent: Wednesday, November 19, 2008 5:10 PM
If a layer preview fails you should generally add that layer to a new
map to see if the extent information and coordinate system are set
correctly. Often times the extent values are not correct.
Regards,
Dave
Dennis (Aviation)
Sent: Wednesday, November 19, 2008 9:04 AM
Haris,
MGOS 2.0.2 on MS2003 Server, using MG Studio 2009 for the rest of it.
Installed your .8 release.
Feature Source
            Connection ... OK
            Set coorsys Override... OK
            save ... OK
Create Layer:
            Fetched all 200+ Feauture Classes ... OK
            Properties.. OK
            Layer Preview:
                        a)nothing ... should have 20000+ geometries in
one of the selected feature class'
                        b)tried a bunch of different tables ... nothing
I don't get any errors logged anywhere that I can find.
I had downloaded and installed the instant client that was discussed
previously. Obviously we are making connection because you are getting
the list of Feature Classes.
I did both the Override thing and I also tried without the Override
thingee(It was populated correctly)
r,
dennis
E-mails are automatically scanned for viruses using McAfee.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20081119/4214afb8/attachment.html
