[mapguide-users] Sample application Problem
padmini godavarthi
godavarthi.padmini at gmail.com
Thu Nov 20 06:25:14 EST 2008
Sorry for the trouble
but i didnt get ur answer
check the url you are calling and what exists on under the \www directory
the url should match the filesystem, if it doesn't you have the wrong url
Plz tell me the breif discription
Thanks,
Padmini.
zspitzer wrote:
> you got a 404 message, changing url parameters will not make any
> difference
> z
> On Thu, Nov 20, 2008 at 10:10 PM, padmini godavarthi
> <godavarthi.padmini at gmail.com> wrote:
>> Hi,
>> Thanks for u r reply.
>> i think the problem might be with sample data given in the sample
>> application.
>> String webLayout =
>> "Library://Samples/Sheboygan/Layouts/SheboyganAsp.WebLayout";
>> and i changed this in to
>> String webLayout = "Library://Example/Maplayout.WebLayout";
>> but it gives the same error .i didn't get any solution for that.
>> If u tell the answer it will be more helpful to me
>> My Configuration is
>> .net 2005
>> IIS 5.1
>> Mapguide opensource 2.0 ( with IIS Configuration + .Net language)
>> Thanks and Regards,
>> Padmini
>> zspitzer wrote:
>>> I'm happy to help, but can firstly have another look at the error
>>> message,
>>> the folders involved and your IIS configuration and try to work it out
>>> yourself?
>>> On Thu, Nov 20, 2008 at 9:38 PM, padmini godavarthi
>>>> Hi
>>>> Thanks for ur reply.
>>>> i changed the configuration file path given by u.
>>>> and while running the application i got an error that
>>>> Server Error in '/' Application.
>>>> The resource cannot be found.
>>>> Description: HTTP 404. The resource you are looking for (or one of its
>>>> dependencies) could have been removed, had its name changed, or is
>>>> temporarily unavailable. Please review the following URL and make sure
>>>> that
>>>> it is spelled correctly.
>>>> Requested URL: /mapviewernet/ajaxviewer.aspx
>>>> Version Information: Microsoft .NET Framework Version:2.0.50727.832;
>>>> ASP.NET
>>>> Plz help me.
>>>> Regards,
>>>> Padmini
>>>> zspitzer wrote:
>>>>>> Configuration file "C:\Program
>>>>>> Files\MapGuideOpenSource2.0\WebServerExtensions\www\dotnetviewersample\dotnetviewersample\../webconfig.ini"
>>>>>> cannot be found or cannot be opened.
>>>>> looking at that url, you have installed the sample wrong
>>>>> should be
>>>>> WebServerExtensions\www\dotnetviewersample\../webconfig.ini
>>>>> z
>>>>> Zac Spitzer -
>>>>> http://zacster.blogspot.com
>>>>> http://ennoble.dreamhosters.com/mapguide-central/
>>>>> +61 405 847 168
>>>>> _______________________________________________
>>>>> mapguide-users mailing list
>>>>> mapguide-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>>> View this message in context:
>>>> http://www.nabble.com/Sample-application-Problem-tp20576129p20598557.html
>>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>> Zac Spitzer -
>>> +61 405 847 168
>> http://www.nabble.com/Sample-application-Problem-tp20576129p20599024.html
> Zac Spitzer -
> +61 405 847 168
View this message in context: http://www.nabble.com/Sample-application-Problem-tp20576129p20599227.html
