[mapguide-users] New King.Oracle 0.8 - improved performance
Nick Adams nick.adams at 1spatial.com
Thu Nov 20 11:04:11 EST 2008
0.8.4 is giving the same error:
Attempted to read or write protected memory. This is often an indication
that other memory is corrupt.
Nick
Nick Adams wrote:
> Ok. I've tried 0.8.3 and I'm now getting:
> Nick
> haris kurtagic wrote:
>> I posted 0.8.3 which should fix first problem.
>> Regarding SDO_FILTER If I remember correcly that is problem with 9.1 (
>> provider works in 9.2 ? ).
>> I don't have 9 versions available to test but if I look at docs and you
>> try it perhaps we can fix it without me trying it.
>> Haris
>> -----Original Message-----
>> From: mapguide-users-bounces at lists.osgeo.org
>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Nick Adams
>> Sent: Thursday, November 20, 2008 3:55 PM
>> To: mapguide-users at lists.osgeo.org
>> Subject: RE: [mapguide-users] New King.Oracle 0.8 - improved performance
>> - I have been using OracleSchema and it was set to the same as the
>> username
>> - Previously I was using 0.7.4.
>>   Unfortunately this didn't work. Then I was getting the error:
>>   ORA-29900: operator binding does not exist ORA-06553: PLS-306: wrong
>> number or types of arguments in call to 'SDO_FILTER'
>> This I understand to be down to the fact that SDO_FILTER requires 3
>> arguments in 9i where-as the third one is optional in 10g. I was hoping
>> 0.8.x might solve this.
>> Nick
>>> I am looking at code and I have two questions :
>>> - are you using connection property OracleSchema, and value is same as
>>> UserName ?
>>> - this has worked for you before release 0.8.2 ?
>>> Haris
>> Adams
>>> Sent: Thursday, November 20, 2008 2:57 PM
>>> Subject: Re: [mapguide-users] New King.Oracle 0.8 - improved
>> performance
>>> Hi Haris,
>>> I've just downloaded version 0.82 a tried it.
>>> The problem I'm working on is using the King Oracle provider with .Net
>>> to
>>> connect to a 9i oracle database.
>>> The query I'm making is:
>>> SHAPE ENVELOPEINTERSECTS GeomFromText('POLYGON ((325400 701400, 325600
>>> 701400, 325600 701600, 325400 701600, 325400 701400))')
>>> The current error it's giving me when I try this is:
>>> ORA-00904: "C"."SDO_INDEX_OWNER": invalid identifier
>>> Any suggestions would be appreciated.
>>> Nick
>>>> Hi,
>>>> I have released new version of King.Oracle provider 0.8.
>>>> It is much faster than previous releases. Lot of code is changed.
>>>> King.Oracle passed my UniTests but it has to be tested more so your
>>>> feedback is appreciated.
>>>> List of changes:
>>>> Improved performance - very significant improvement
>>>> Support for SelectAggregate
>>>> FDO schema creation is now faster , especially when
>>> OracleScema=UserName
>>>> Reintroduced schema caching
>>>> Full Unicode support
>>>> Using OCI interface
>>>> You can get it here: www.sl-king.com/fdooracle
>>>> Haris
>>>> _______________________________________________
>>>> mapguide-users mailing list
>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>> View this message in context:
>> http://www.nabble.com/New-King.Oracle-0.8---improved-performance-tp20580
>>> 002p20601567.html
>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> 002p20602909.html
View this message in context: http://www.nabble.com/New-King.Oracle-0.8---improved-performance-tp20580002p20604513.html
