[mapguide-users] Installation mapguide 64bits
Andy Morsell amorsell at spatialgis.com
Thu Nov 20 12:33:58 EST 2008
I've installed MGOS in the past on 64-bit using WOW32 without any major
issues.  If using IIS, you must ensure that you are using the 32 bit version
of IIS.
Andy Morsell, P.E.
Spatial Integrators, Inc.
www.SpatialGIS.com
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
Sent: Thursday, November 20, 2008 4:09 AM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] Installation mapguide 64bits
based on what i'm seeing going on via trac, 2.1 might support  64-bit :)
2.0.x definitely doesn't work, the wow-something (32?) support might work
tho
z
On Thu, Nov 20, 2008 at 11:02 PM, gingerbbm <stuart.jones at jacobs.com> wrote:
> I've installed on Windows Server 2003 64-bit and it certainly doesn't seem
to
> work. When I try the functionality in the PHP sample I end up with
"Service
> Unavailable" and a bunch of messages like this in the event viewer:
> "A process serving application pool 'MapGuide' terminated unexpectedly.
The
> process id was '4056'. The process exit code was '0xe06d7363'."
> And ultimately:
> "Application pool 'MapGuide' is being automatically disabled due to a
series
> of failures in the process(es) serving that application pool."
> I'm using MapGuide Enterprise 2009 but I assume the same goes for MGOS.
> Does anyone have any information on this?
> Thanks
> Stuart
http://n2.nabble.com/Installation-mapguide-64bits-tp1365405p1556838.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer -
http://zacster.blogspot.com
http://ennoble.dreamhosters.com/mapguide-central/
+61 405 847 168
