[mapguide-users] mgstudio 2009 Installation problem on vista
Mark Pendergraft markp at Meadgilman.com
Fri Nov 21 17:18:48 EST 2008
I know this post is 2 months old, but i just wanted people to know that you
can in fact run MapGuide Studio 2009 on a Vista x64 machine.  You need to
use the corflags tool provided with VS2005 to force the studio.exe file to
operate in the WOW64 environment.
The process is detailed here:
http://rickonrails.wordpress.com/2008/09/24/how-to-hack-mapguide-studio-to-run-on-64-bit-windows/
As mentioned, this fix requires Visual Studio 2005, i have 2008 installed on
my new machine and wasn't able to apply it with this.  I had to do it on my
old machine, and copy the file over.
-Mark Pendergraft
Darrin Maidlow wrote:
> Hi Rodolfo,
> Is your Vista machine running the 64 bit version of Vista?  If so, you
> cannot install Studio on that machine.  I tried changing the .ini file
> similar to what can be done with AutoCAD Map and Studio will install - but
> it crashes as soon as you run it.  I've had to resort to a virtual machine
> running a 32 bit OS.
> darrin
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Rodolfo
> Moreno
> Sent: Friday, September 05, 2008 9:54 AM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] mgstudio 2009 Installation problem on vista
> Hi all,
> I am having a problem during the installation process.
> I have installed mgstudio 2009 trial version on window server 2003 sp2
> without problem, however when I tried to install on window vista I got an
> error message on the first time. In my second attemp the link showed up
> disabled, which is why I couldn't got the accurate error message.
> I will appreciate any suggestion.
> Rodolfo Moreno
> CivilEng
> http://n2.nabble.com/mgstudio-2009-Installation-problem-on-vista-tp841474p84
> 1474.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
View this message in context: http://n2.nabble.com/mgstudio-2009-Installation-problem-on-vista-tp841474p1563800.html
