[mapguide-users] Creating Streets and info
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Mon Nov 24 07:56:03 EST 2008
I am no expert on SHP data, but with most data, the attributes are included.
If you use SHP data in MapGuide the attributes should be IN the SHP (or
is it dbx, etc) file.
From then on you can see the columns everywhere, and use the attributes
as label or other stuff.
If you select the columns to view on the layer, they will show up, just
like the parcel data.
If you use Arc, the attributes are also attached to the topology, so the
export should be able to extract that as well.
Regards, Kenneth Skovhede, GEOGRAF A/S
Carmelo Saffioti skrev:
> Thank you for your help.
> I've found how to create object data. The problem is that I've got many
> objects (about 10.000), then I need an automatic method to attach data to
> objects. Some people told me to follow these steps:
> 1) create a topology
> 2) export a SHP file with topology data
> 3) use topology ID to make a JOIN between topology data and data I need to
> attach
> 4) import in Autocad Map the SHP file
> 5) label objects, using the Style tool
> 6) create a link template
> 7) generate links to "Enclosed Text"
> On Autocad Map guide I saw that it is possible to automatically link objects
> to data on a DB table. But it requires labels. Using labels created as I
> said here doesn't work...
> Other people told me to attach objects data using a GIS software, but did
> not say which software and how :-(
> I hope anybody here can help me, because it's taking a really long time for
> this purpose...
> I need to develop something similar to the ajaxviewer example, on which you
> can view info about Parcels.
> Hoping in your help
> Cheers
> Carmelo
> ----- Original Message -----
> From: "Berdel, Brian" <brian.berdel at mcmtrans.com>
> To: "MapGuide Users Mail List" <mapguide-users at lists.osgeo.org>
> Sent: Tuesday, November 18, 2008 2:45 PM
> Subject: RE: [mapguide-users] Creating Streets and info
> In autocad map you have to create the object data and attach it to the
> features. Check the help for creating object data. It is pretty
> straight forward once you know what you are doing.
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Carmelo
> Saffioti
> Sent: Tuesday, November 18, 2008 8:49 AM
> To: MapGuide Users Mail List
> Subject: Re: [mapguide-users] Creating Streets and info
> Thanks Zac.
> You said that the street layer tooltip is based on attributes chosen
> from
> the feature source. Looking with Maestro at the viewer example I see
> what
> you mean. Then now I need to create a feature source with attributes.
> The
> feature source I'm using is a SHP file exported from my DWG planimetry
> with
> Autocad Map. Importing it into MapGuide I can see that it has only 1
> attribute: FeatId.
> I saw that the viewer example uses a layer called "Parcels", which has
> many
> attributes. I need something similar, because on my planimetry I have
> many
> adiacents blocks, and for each of them I need to show a tooltip with
> detail
> informations (for example: Row number, Block number, Area code).
> Have I create this blocks, with their detail informations, on Autocad
> Map?
> I tried importing the Parcel SDF file features source into Autocad Map,
> and
> I see that each block is a poliline. But I don't see any attribute, I
> don't
> know how to...
> From: "Zac Spitzer" <zac.spitzer at gmail.com>
> Sent: Tuesday, November 18, 2008 12:29 PM
>> have a look at how the example you looked at is configured
>> the street layer will expose a tooltip based on the attributes chosen
>> from the feature source in the tooltip expression
>> z
>> On Tue, Nov 18, 2008 at 10:29 PM, Carmelo Saffioti <csaffi at libero.it>
> wrote:
>>> Thank you for your answer.
>>> I'm using Maestro. Ok, I see that the tooltip is definable on the
> layer
> with
>>> Maestro.
>>> So, to have a tooltip for each street should I have a layer for each
> street?
>>> Sent: Tuesday, November 18, 2008 12:15 PM
>>>> what tools are you using? studio, maestro?
>>>> they are called tooltips and they are defined per layer
>>>> On Tue, Nov 18, 2008 at 10:12 PM, Carmelo Saffioti
>>> wrote:
>>>>> Hi everybody,
>>>>> Seeing the MapGuide viewer example I saw that when the mouse
> cursor
> is
>>> over
>>>>> a street it displays a message with informations about the
> street.
> I'd
>>> like
>>>>> to make something similar. I need to create streets and infos
> too.
> How
>>> can I
>>>>> do?
>>>>> I hope you can help me starting
>>>>> Cheers
>>>>> Carmelo
>>>>> _______________________________________________
>>>>> mapguide-users mailing list
>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>>> Zac Spitzer -
>>>> http://zacster.blogspot.com
>>>> http://ennoble.dreamhosters.com/mapguide-central/
>>>> +61 405 847 168
>> Zac Spitzer -
>> +61 405 847 168
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20081124/8829f468/attachment.html
