[mapguide-users] Creating Streets and info
Carmelo Saffioti
csaffi at libero.it
Tue Nov 25 02:48:44 EST 2008
My local reference system is metric, and its origin is a (0,0) point on the planimetry.
Then, do you mean to set a metric system for both data sources and the map?
The question is this:
Data sources have metric data on a local reference system. Then the map is generated by this system. I have a sequence of GPS vehicles positions too, which must be displayed on the map. Have I transform GPS positions to local system coordinates (or the map coordinates to GPS)?? Or is there any other way?
Thank you again
Cheers
Carmelo
----- Original Message -----
To: MapGuide Users Mail List
Sent: Monday, November 24, 2008 9:47 PM
Subject: Re: [mapguide-users] Creating Streets and info
If you select the correct projection for both the data sources, and the map,
MapGuide should fix it correctly for you.
If you have X/Y data (lat/lon) in MySql, you can use the ODBC provider to map the data into points.
Regards, Kenneth Skovhede, GEOGRAF A/S
Carmelo Saffioti skrev:
Thank you Kenneth, now it works :-)
Another question:
I've got objects coordinates and data on a MySql DB. Is it possible to use it to draw a layer with these objects?
Object coordinates are local relative coordinates. Vehicles positions on my DB are lat/lon GPS coordinates. Have you got any suggestions about dealing with these different coordinates?
Thank you very much again
Cheers
Carmelo
Sent: Monday, November 24, 2008 3:29 PM
I see the problem now.
You must include ALL the files, not just the SHP file.
After that you must select the shp file to be the "main" item (the star button in Maestro).
I can send you a package where I have done this if you like.
The problem is that Maestro only displays "*.shp" in the file type, and you must select "All files" before you can add those other files.
Feel free to add a feature request for the problem:
http://trac.osgeo.org/mapguide/newticket
I tried using the exported SHP file with MapGuide Maestro. Using the ajaxviewer example SDF files I see many attributes, but using my exported SHP files I see only the FeatId field. If from Autocad Map I export data to SDF format I've got the same problem...
If from Autocad Map I connect to the SHP data file I can see its attributes values on the data table. How come MapGuide Maestro doesn't display them?
The SHP file is attached with this message,
please help me
Sent: Monday, November 24, 2008 1:56 PM
I am no expert on SHP data, but with most data, the attributes are included.
If you use SHP data in MapGuide the attributes should be IN the SHP (or is it dbx, etc) file.
>From then on you can see the columns everywhere, and use the attributes as label or other stuff.
If you select the columns to view on the layer, they will show up, just like the parcel data.
If you use Arc, the attributes are also attached to the topology, so the export should be able to extract that as well.
Thank you for your help.
I've found how to create object data. The problem is that I've got many
objects (about 10.000), then I need an automatic method to attach data to
objects. Some people told me to follow these steps:
1) create a topology
2) export a SHP file with topology data
3) use topology ID to make a JOIN between topology data and data I need to
attach
4) import in Autocad Map the SHP file
5) label objects, using the Style tool
6) create a link template
7) generate links to "Enclosed Text"
On Autocad Map guide I saw that it is possible to automatically link objects
to data on a DB table. But it requires labels. Using labels created as I
said here doesn't work...
Other people told me to attach objects data using a GIS software, but did
not say which software and how :-(
I hope anybody here can help me, because it's taking a really long time for
this purpose...
I need to develop something similar to the ajaxviewer example, on which you
can view info about Parcels.
Hoping in your help
Cheers
Carmelo
From: "Berdel, Brian" <brian.berdel at mcmtrans.com>
To: "MapGuide Users Mail List" <mapguide-users at lists.osgeo.org>
Sent: Tuesday, November 18, 2008 2:45 PM
Subject: RE: [mapguide-users] Creating Streets and info
In autocad map you have to create the object data and attach it to the
features. Check the help for creating object data. It is pretty
straight forward once you know what you are doing.
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Carmelo
Saffioti
Sent: Tuesday, November 18, 2008 8:49 AM
Thanks Zac.
You said that the street layer tooltip is based on attributes chosen
from
the feature source. Looking with Maestro at the viewer example I see
what
you mean. Then now I need to create a feature source with attributes.
The
feature source I'm using is a SHP file exported from my DWG planimetry
with
Autocad Map. Importing it into MapGuide I can see that it has only 1
attribute: FeatId.
I saw that the viewer example uses a layer called "Parcels", which has
many
attributes. I need something similar, because on my planimetry I have
many
adiacents blocks, and for each of them I need to show a tooltip with
detail
informations (for example: Row number, Block number, Area code).
Have I create this blocks, with their detail informations, on Autocad
Map?
I tried importing the Parcel SDF file features source into Autocad Map,
and
I see that each block is a poliline. But I don't see any attribute, I
don't
know how to...
Sent: Tuesday, November 18, 2008 12:29 PM
have a look at how the example you looked at is configured
the street layer will expose a tooltip based on the attributes chosen
from the feature source in the tooltip expression
z
On Tue, Nov 18, 2008 at 10:29 PM, Carmelo Saffioti <csaffi at libero.it>
wrote:
Thank you for your answer.
I'm using Maestro. Ok, I see that the tooltip is definable on the
layer
with
Maestro.
So, to have a tooltip for each street should I have a layer for each
street?
Sent: Tuesday, November 18, 2008 12:15 PM
what tools are you using? studio, maestro?
they are called tooltips and they are defined per layer
On Tue, Nov 18, 2008 at 10:12 PM, Carmelo Saffioti
wrote:
Hi everybody,
Seeing the MapGuide viewer example I saw that when the mouse
cursor
is
over
a street it displays a message with informations about the
street.
I'd
like
to make something similar. I need to create streets and infos
too.
How
can I
do?
I hope you can help me starting
Cheers
Carmelo
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
Zac Spitzer -
http://zacster.blogspot.com
http://ennoble.dreamhosters.com/mapguide-central/
+61 405 847 168
Zac Spitzer -
+61 405 847 168
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20081125/c8277320/attachment.html
