[mapguide-users] Scribble2
Pedro Venâncio pedrongvenancio at yahoo.com
Tue Nov 25 22:47:37 EST 2008
Well I am using MGOS 2.0.2 with IIS and PHP and then this directory
does not exist ... Instead of that I got
C:\Programas\MapGuideOpenSource2.0\WebServerExtensions\www\mapviewerphp
but has no bin folder or dll...
 Does Scribble only works with dot Net instead of php?
 Thank you very much!
Regards,
Pedro
--- On Wed, 11/26/08, Andy Morsell <amorsell at spatialgis.com> wrote:
Subject: RE: [mapguide-users] Scribble2
To: "'MapGuide Users Mail List'" <mapguide-users at lists.osgeo.org>
Date: Wednesday, November 26, 2008, 12:30 AM
I meant the MapGuide specific dll files.  The ones that came with the zip are from
2.0.1 and should be replaced if you’re not using that version.  I added this sentence to the installation
paragraph:
“Copy the MapGuide dll files from
C:\Program Files\MapGuideOpenSource2.0\WebServerExtensions\www\mapviewernet\bin
to your Scribble\bin directory.”
Andy
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Pedro Venâncio
Sent: Tuesday, November 25, 2008
11:15 AM
To: MapGuide Users Mail List
Scribble2
  Hi Andy
  No, all the
  application gives me the message "Error encountered within
  application"...
  I've instaled the application just like this:
  To use this package: unzip to a folder of your choice. Create a new virtual
  directory in IIS called Scribble under your existing mapguide virtual
  directory. Open your web layout in Studio and create a new Invoke URL custom
  command that points to ../Scribble/scribble.aspx with the task pane being the
  target. Add this custom command to your task bar menu or toolbar. Open your
  layout and invoke your custom URL.
  Those dlls (
  itext-2.0.6.dll, IKVM.Runtime.dll, IKVM.GNU.Classpath.dll,
  bcprov-jdk15-137.dll,
   bcmail-jdk15-137.dll) are already in the MGOS2 Scribble Package. It is
  necessary to replace them? What is the correct ones?
  Thanks!
  Regards,
  Pedro
  --- On Tue, 11/25/08, Andy Morsell <amorsell at spatialgis.com>
  Date: Tuesday, November 25, 2008, 6:10 PM
  Does the rest of the Scribble
  application work for you?  Are you only having problems with the PDF
  portion?  Did you copy the MGOS dll files into the Scribble bin directory?
  Andy
  7:33 AM
  To:
  Subject: [mapguide-users]
  Scribble2
      Hello!
      I am trying to install the
      package of Scribble (from Andy), but it gives me the error of the image
      attached. Then, when I click "PDF Document", show me this
      message:
      Server Error in '/mapguide/Scribble'
      Application.
      Failed to retrieve
      message for "MgConfigurationException".
      Description: An unhandled exception occurred
      during the execution of the current web request. Please review the stack
      trace for more information about the error and where it originated in the
      code.
      Exception Details: OSGeo.MapGuide.MgConfigurationException:
      Failed to retrieve message for "MgConfigurationException".
      Source Error:
        Line 843:        this._session = session;
Line 844:        this._site = new MgSiteConnection();
      Line 845:        this._site.Open(new MgUserInformation(session));
      Line 846:        this._Session_StringBuilder = new StringBuilder();
Line 847:        this._Session_StringBuilder.Append("Session:");
      Source File: c:\Programas\MapGuideOpenSource2.0\Scribble\App_Code\scribblemethodsmgr.cs    Line: 845
      Stack Trace:
        [MgConfigurationException: Failed to retrieve message for "MgConfigurationException".]
   OSGeo.MapGuide.SWIGExceptionHelper.ThrowCustomException(String className, IntPtr cptr) +176
   OSGeo.MapGuide.MapGuideApiPINVOKE.MgSiteConnection_Open(IntPtr jarg1, IntPtr jarg2) +0
   OSGeo.MapGuide.MgSiteConnection.Open(MgUserInformation userInformation) +20
   ScribbleMethodsMgr.SetUp(String session, String mapname) in c:\Programas\MapGuideOpenSource2.0\Scribble\App_Code\scribblemethodsmgr.cs:845
   ScribbleMethodsMgr.MaterializeMapPDFPage(String session, String mapname, Int32 width, Int32 height, String imageflavor) in c:\Programas\MapGuideOpenSource2.0\Scribble\App_Code\scribblemethodsmgr.cs:603
   scribblepdfdoc.ProcessRequest(HttpContext context) in c:\Programas\MapGuideOpenSource2.0\Scribble\scribblepdfdoc.ashx:11
   System.Web.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +154
 System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +64
      Version Information: Microsoft .NET Framework
      Version:2.0.50727.42; ASP.NET Version:2.0.50727.42
      I followed all the
      steps listed for the use of the package, but I am using the MGOS 2.0.2
      with php on IIS 5.1. This may be the problem?
      Yours sincerely,
      Pedro
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20081125/27634dc2/attachment.html
