[mapguide-users] Scribble2
Pedro Venâncio
pedrongvenancio at yahoo.com
Wed Nov 26 11:11:55 EST 2008
Andy,
Thank you very much! It's working!
Regards,
Pedro
--- On Wed, 11/26/08, Andy Morsell <amorsell at spatialgis.com> wrote:
Subject: RE: SPAM-LOW: RE: [mapguide-users] Scribble2
To: pedrongvenancio at yahoo.com, "'MapGuide Users Mail List'" <mapguide-users at lists.osgeo.org>
Date: Wednesday, November 26, 2008, 4:20 AM
Yes, Scribble requires the MGOS .NET web
extensions. You can install the .NET web
extensions side-by-side with the PHP web extensions without any problems if you
want to give that a try.
Andy
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Pedro Venâncio
Sent: Tuesday, November 25, 2008
7:48 PM
To: MapGuide Users Mail List
Subject: SPAM-LOW: RE:
Well I am using MGOS 2.0.2 with IIS and PHP and then
this directory does not exist ... Instead of that I got
C:\Programas\MapGuideOpenSource2.0\WebServerExtensions\www\mapviewerphp
but has no bin folder or dll...
Does Scribble only works with dot Net instead of php?
Regards,
Pedro
Subject: RE: [mapguide-users] Scribble2
To: "'MapGuide Users Mail List'"
Date: Wednesday, November 26, 2008, 12:30 AM
I meant the MapGuide specific dll
files. The ones that came with the zip are from 2.0.1 and should be
replaced if youre not using that version. I added this sentence
to the installation paragraph:
Copy the MapGuide dll files from
C:\Program
Files\MapGuideOpenSource2.0\WebServerExtensions\www\mapviewernet\bin to your
Scribble\bin directory.
Andy
11:15 AM
Scribble2
Hi Andy
No, all the
application gives me the message "Error encountered within
application"...
I've instaled the application just like this:
To use this package: unzip to a folder of your choice. Create a new virtual
directory in IIS called Scribble under your existing mapguide virtual
directory. Open your web layout in Studio and create a new Invoke URL
custom command that points to ../Scribble/scribble.aspx with the task pane
being the target. Add this custom command to your task bar menu or toolbar.
Open your layout and invoke your custom URL.
Those dlls (
itext-2.0.6.dll, IKVM.Runtime.dll, IKVM.GNU.Classpath.dll,
bcprov-jdk15-137.dll,
bcmail-jdk15-137.dll) are already in the MGOS2 Scribble Package. It
is necessary to replace them? What is the correct ones?
Thanks!
Regards,
Pedro
--- On Tue, 11/25/08, Andy Morsell <amorsell at spatialgis.com>
Date: Tuesday, November 25, 2008, 6:10 PM
Does the rest of
the Scribble application work for you? Are you only having problems
with the PDF portion? Did you copy the MGOS dll files into the
Scribble bin directory?
Andy
2008 7:33 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users]
Scribble2
Hello!
I am trying to install the
package of Scribble (from Andy), but it gives me the error of the image
attached. Then, when I click "PDF Document", show me this
message:
Server Error in '/mapguide/Scribble'
Application.
Failed to retrieve
message for "MgConfigurationException".
Description: An unhandled exception
occurred during the execution of the current web request. Please review
the stack trace for more information about the error and where it
originated in the code.
Exception Details: OSGeo.MapGuide.MgConfigurationException:
Failed to retrieve message for "MgConfigurationException".
Source Error:
Line 843: this._session = session;
Line 844: this._site = new MgSiteConnection();
Line 845: this._site.Open(new MgUserInformation(session));
Line 846: this._Session_StringBuilder = new StringBuilder();
Line 847: this._Session_StringBuilder.Append("Session:");
Source File: c:\Programas\MapGuideOpenSource2.0\Scribble\App_Code\scribblemethodsmgr.cs Line: 845
Stack Trace:
[MgConfigurationException: Failed to retrieve message for "MgConfigurationException".]
OSGeo.MapGuide.SWIGExceptionHelper.ThrowCustomException(String className, IntPtr cptr) +176
OSGeo.MapGuide.MapGuideApiPINVOKE.MgSiteConnection_Open(IntPtr jarg1, IntPtr jarg2) +0
OSGeo.MapGuide.MgSiteConnection.Open(MgUserInformation userInformation) +20
ScribbleMethodsMgr.SetUp(String session, String mapname) in c:\Programas\MapGuideOpenSource2.0\Scribble\App_Code\scribblemethodsmgr.cs:845
ScribbleMethodsMgr.MaterializeMapPDFPage(String session, String mapname, Int32 width, Int32 height, String imageflavor) in c:\Programas\MapGuideOpenSource2.0\Scribble\App_Code\scribblemethodsmgr.cs:603
scribblepdfdoc.ProcessRequest(HttpContext context) in c:\Programas\MapGuideOpenSource2.0\Scribble\scribblepdfdoc.ashx:11
System.Web.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +154
System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +64
Version Information: Microsoft
.NET Framework Version:2.0.50727.42; ASP.NET Version:2.0.50727.42
I followed all the
steps listed for the use of the package, but I am using the MGOS 2.0.2
with php on IIS 5.1. This may be the problem?
Yours sincerely,
Pedro
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20081126/b0fc607e/attachment.html
