Re[mapguide-users] fresh map in DotNetSamples
Jackie C. Ng jumpinjackie at gmail.com
Thu Nov 27 10:14:45 EST 2008
You have to programmatically refresh from the client side (AJAX Viewer)
Your .net code runs on the server side so it has to either write the
refresh() javascript call as part of the page response (if running in the
task pane or InvokeURL command) or write a special value that the client
understands as an order to refresh the map (if using XMLHttpRequest)
- Jackie
euskalmap wrote:
> Hi,
> I try the layout DotNetSamples in MAPOSE 2.0.
> When i test the functionnality 'Rename Roads Layer', why do i refresh
> manually the map ?
> In your code (TOGGLE_LAYER_LABEL.ASPX.CS) there is the instrucion
> 'map.Save(resourceService)' : why the map is not refresh ?
> Thanks
http://themapguyde.blogspot.com
http://www.linkedin.com/in/jackieng
View this message in context: http://www.nabble.com/Refresh-map-in-DotNetSamples-tp20717714p20720866.html
