[mapguide-users] Drawing layer reading coordinates from DB
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Thu Nov 27 15:38:01 EST 2008
AFAIK, there is no way to draw rectangles from corner points without
creating the geometries and inserting them.
If you read out the geometry, it is quite easy to read the coordinates
(which will be cornes in a rectangle).
Regards, Kenneth Skovhede, GEOGRAF A/S
Carmelo Saffioti skrev:
> Hi everybody,
> I've got a MySql DB on which there are objects coordinates. For
> example I've got coordinates of slots centers, where a slot is a
> rectangle. For other rectangles I've got the coordinates of each of
> the 4 corners.
> Is it possible to draw a rectangle reading its center coordinates?
> And is it possible knowing its corners coordinates?
> Cheers
> Carmelo
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20081127/c2edac61/attachment.html
