[mapguide-users] How to Load Runtime map in mapviewerajax
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Fri Nov 28 04:28:25 EST 2008
If you want to create a WebLayout using the MaestroAPI, simpy do:
MaestroAPI.ServerConnectionI con; //You need this from the
code in the example
MaestroAPI.WebLayout layout = new MaestroAPI.WebLayout();
layout.Map = new MaestroAPI.MapType();
layout.Map.ResourceId = "Library://mymap.MapDefinition";
con.SaveResourceAs(layout, "Library://mylayout.WebLayout");
You might also want to add some buttons and set other options.
Regards, Kenneth Skovhede, GEOGRAF A/S
padmini godavarthi skrev:
> Hi,
> Thanks for u r reply.
> Actually i have created one mgp in mapguide maestro.
> so i placed it in the ajaxviewer sample application as
> weblayout="Library://Layout/maplayout.weblayout.
> It works fine
> Now i want to create it by coding using (Maestroapi.dll) dynamically so i
> saw a link
> http://trac.osgeo.org/mapguide/wiki/maestro/MaestroAPI/samples/AddInitialLayer
> but i didnt get the code
> So plz tell me the procedure sothat i will proceed further development
> Regards,
> Padmini
> Maksim Sestic wrote:
>> Then check the last few lines of this example:
>> er
>> ...but I suggest you reading a bit about MeastroAPI in general:
>> Regards,
>> Maksim Sestic
>> -----Original Message-----
>> From: mapguide-users-bounces at lists.osgeo.org
>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of padmini
>> godavarthi
>> Sent: Thursday, November 27, 2008 02:22
>> To: mapguide-users at lists.osgeo.org
>> Subject: RE: [mapguide-users] How to Load Runtime map in mapviewerajax
>> Hi,
>> I followed the given url
>> http://trac.osgeo.org/mapguide/wiki/maestro/MaestroAPI/samples/RuntimeMap
>> i got an session id for that. After getting it iam unable to get what to
>> do
>> with that?
>> can u plz tell me the procedure.
>> Regards,
>> padmini
>>> You might check this out first:
>>> Map
>>> I guess it does exactly what you need.
>>> Regards,
>>> Maksim Sestic
>>> godavarthi
>>> Sent: Wednesday, November 26, 2008 17:15
>>> Subject: [mapguide-users] How to Load Runtime map in mapviewerajax
>>> Hi,
>>> iam using Mapguide opensource 2.0 (with .net 2.0+IIS 5.1).
>>> Now i want to load a runtime map (using MaestroAPI.dll) in to
>>> mapviewer ajax application (in .net)
>>> Plz tell me the procedure for
>>> 1) How to load the runtime map?
>>> 2) What are the steps i have to follow?
>>> If anybody knows plz help me
>>> Regards,
>>> Padmini
>>> View this message in context:
>>> http://www.nabble.com/How-to-Load-Runtime-map-in-mapviewerajax-tp20704
>>> 038p20
>>> 704038.html
>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>> mapguide-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>> __________ Information from ESET NOD32 Antivirus, version of virus
>>> signature database 3643 (20081126) __________
>>> The message was checked by ESET NOD32 Antivirus.
>>> http://www.eset.com
>>> http://www.eset.com
>> http://www.nabble.com/How-to-Load-Runtime-map-in-mapviewerajax-tp20704038p20
>> 712155.html
>> signature
>> database 3644 (20081126) __________
>> http://www.eset.com
>> signature
>> http://www.eset.com
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20081128/ac05cf06/attachment.html
