[mapguide-users] No input variables have been defined in SQL statement
Kirk Yedinak
admin at hitechvalue.net
Fri Nov 28 15:26:45 EST 2008
Hello,
Here are the basics:
SQL 2005, MapGuide Open Source (latest version), King FDO for MSSQL
I've set up database connection using the King FDO. I created a layer to
display my points and polygons from the database. That part works fine.
However, when I attempt to select a feature from the layer that uses the
King FDO, my error log indicates the following:
Error: An exception occurred in FDO component.
StackTrace:
- MgRenderingServiceHandler.ProcessOperation line 83 file
d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\rendering\RenderingServiceHandler.cpp
- MgOpQueryFeatures.Execute line 125 file
d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\rendering\OpQueryFeatures.cpp
- MgServerRenderingService.QueryFeatures line 652 file
d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\rendering\ServerRenderingService.cpp
- MgServerRenderingService.RenderForSelection line 1326 file
- MgServerSelectFeatures.SelectFeatures line 249 file
d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\feature\ServerSelectFeatures.cpp
Any help would be appreciated.
Kirk
View this message in context: http://n2.nabble.com/No-input-variables-have-been-defined-in-SQL-statement-tp1590404p1590404.html
