[mapguide-users] RE: Tiffs and MGOS 2.01
Dave Wilson dave.wilson at autodesk.com
Wed Oct 1 19:12:05 EDT 2008
Did you specify a coordinate system override on your Data connection so that when you add the layer to the map it knows what CS it's in?
Dave
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Mark Pendergraft
Sent: Wednesday, October 01, 2008 4:56 PM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Tiffs and MGOS 2.01
I'm having trouble with TIFF's in MGOS 2.01.  I'm using Mapguide Studio 2009 and the GDAL provider.  I can create a data resource from a directory containing 4 tiffs (downloaded from USGS National Map - NED Imagery).  And I'm able to create a layer, and view the tiff data in the layer preview.  Everything is fine until I add it into my map.  It doesn't show up at all.  I have even made another map with just the tiff layer, and zoomed way out.  Nothing.  I have tried different coordinate systems, and I'm currently using the LL83 (which is the same as the tiff coordinate system) and I've even plugged in the lat/longs from the tiff's lower/upper corners into the map.  Am I missing something here?
Thanks.
-Mark Pendergraft
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20081001/33f3c781/attachment.html
