[mapguide-users] RE: Tiffs and MGOS 2.01
Zac Spitzer
zac.spitzer at gmail.com
Thu Oct 2 01:09:46 EDT 2008
opps, I meant http://trac.osgeo.org/mapguide/wiki/MapGuideRfc51
On Thu, Oct 2, 2008 at 3:09 PM, Zac Spitzer <zac.spitzer at gmail.com> wrote:
> coming very soon - http://trac.osgeo.org/mapguide/wiki/MapGuideRfc55
> it was just committed to subversion, you should be able to compile a version
> so you got rasters with GDAL working stably? cool
> z
> On Thu, Oct 2, 2008 at 3:06 PM, Mark Pendergraft <markp at meadgilman.com> wrote:
>> I have upgraded to 2.02 and now I can see the tiff in my map. however, I
>> can only see the tiff in my map when the coordinate system is the same as
>> the coordinate system in the tiff (regardless of overrides). Any ideas?
>> From: mapguide-users-bounces at lists.osgeo.org
>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Mark
>> Pendergraft
>> Sent: Wednesday, October 01, 2008 4:22 PM
>> To: MapGuide Users Mail List
>> Subject: RE: [mapguide-users] RE: Tiffs and MGOS 2.01
>> I did have a coordinate system override specified at first. It was the same
>> coordinate system as my map (WAHP-NF), but when I looked at it in the layer
>> preview, the scale was 1:4.65. Seeing as the TIFF covers the entire Puget
>> Sound in Washington State, I knew something was up. So I didn't specify an
>> override, and I create a new map with the same coordinate system as the
>> tiff. When I look at the tiff in the layer preview sans override, the scale
>> is 1:1698729.00 (which is more like it).
>> However in my map with the same coordinate system, I see nothing.
>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Dave Wilson
>> Sent: Wednesday, October 01, 2008 4:12 PM
>> Subject: [mapguide-users] RE: Tiffs and MGOS 2.01
>> Did you specify a coordinate system override on your Data connection so that
>> when you add the layer to the map it knows what CS it's in?
>> Dave
>> Pendergraft
>> Sent: Wednesday, October 01, 2008 4:56 PM
>> To: mapguide-users at lists.osgeo.org
>> Subject: [mapguide-users] Tiffs and MGOS 2.01
>> I'm having trouble with TIFF's in MGOS 2.01. I'm using Mapguide Studio 2009
>> and the GDAL provider. I can create a data resource from a directory
>> containing 4 tiffs (downloaded from USGS National Map - NED Imagery). And
>> I'm able to create a layer, and view the tiff data in the layer preview.
>> Everything is fine until I add it into my map. It doesn't show up at all.
>> I have even made another map with just the tiff layer, and zoomed way out.
>> Nothing. I have tried different coordinate systems, and I'm currently using
>> the LL83 (which is the same as the tiff coordinate system) and I've even
>> plugged in the lat/longs from the tiff's lower/upper corners into the map.
>> Am I missing something here?
>> Thanks.
>> -Mark Pendergraft
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> Zac Spitzer -
> http://zacster.blogspot.com (My Blog)
> +61 405 847 168
Zac Spitzer -
+61 405 847 168
