[mapguide-users] Scale rendering and layers missing with tile cahe.
MMicallef-MTO Michael.Micallef at ontario.ca
Thu Oct 2 10:35:48 EDT 2008
I am looking for some direction,  I am producing a map for selected features
(a map for each and reiterating through) - I was able - prior to moving to a
tile cache (base layers) - to produce the map with the following built url:
**attached in file
-although it would only show the layers that were turned on in the map
definition
now I think I am getting the tile cache at the smallest scale when rendering
the map - blank due to the scale display setting of the layer
Is there anyway to render the map for a specific scale so that the layers
defined to display at that scale are included - with the nuances of using
base layers (tile caching)?
Mike
http://www.nabble.com/file/p19780541/nable%2Bpst1.txt nable+pst1.txt
View this message in context: http://www.nabble.com/Scale-rendering-and-layers-missing-with-tile-cahe.-tp19780541p19780541.html
