[mapguide-users] RE: Tiffs and MGOS 2.01
Andy Morsell
amorsell at spatialgis.com
Thu Oct 2 13:06:40 EDT 2008
The "on" and "off" settings only apply to bitonal (1 bit) images. There are
no settings that pertain to grayscale or color images. You would have to
pre-process your images with an image editor or something like GDAL Tools in
order to alter their appearance.
Andy Morsell, P.E.
Spatial Integrators, Inc.
www.SpatialGIS.com
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Mark
Pendergraft
Sent: Thursday, October 02, 2008 7:40 AM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] RE: Tiffs and MGOS 2.01
Thanks. I will be looking forward to this.
I did have a question about styling a tiff: is there a way to control
how the tiff is displayed color-wise in the map? When I create the data
resource, there is an option to control the colors of "on" and "off"
pixels. However, when I change these settings, nothing happens. I was
hoping to display my image in a grey/black shading. When I look at the
tiff in my layer preview and map, it has about 10+ colors. More colors
is great, but how do I control their appearance?
Thanks for the help.
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
Sent: Wednesday, October 01, 2008 10:10 PM
Subject: Re: [mapguide-users] RE: Tiffs and MGOS 2.01
opps, I meant http://trac.osgeo.org/mapguide/wiki/MapGuideRfc51
On Thu, Oct 2, 2008 at 3:09 PM, Zac Spitzer <zac.spitzer at gmail.com>
wrote:
> coming very soon - http://trac.osgeo.org/mapguide/wiki/MapGuideRfc55
> it was just committed to subversion, you should be able to compile a
version
> so you got rasters with GDAL working stably? cool
> z
> On Thu, Oct 2, 2008 at 3:06 PM, Mark Pendergraft
<markp at meadgilman.com> wrote:
>> I have upgraded to 2.02 and now I can see the tiff in my map.
however, I
>> can only see the tiff in my map when the coordinate system is the
same as
>> the coordinate system in the tiff (regardless of overrides). Any
ideas?
>> From: mapguide-users-bounces at lists.osgeo.org
>> Pendergraft
>> Sent: Wednesday, October 01, 2008 4:22 PM
>> I did have a coordinate system override specified at first. It was
the same
>> coordinate system as my map (WAHP-NF), but when I looked at it in the
layer
>> preview, the scale was 1:4.65. Seeing as the TIFF covers the entire
Puget
>> Sound in Washington State, I knew something was up. So I didn't
specify an
>> override, and I create a new map with the same coordinate system as
the
>> tiff. When I look at the tiff in the layer preview sans override,
the scale
>> is 1:1698729.00 (which is more like it).
>> However in my map with the same coordinate system, I see nothing.
>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Dave
Wilson
>> Sent: Wednesday, October 01, 2008 4:12 PM
>> Subject: [mapguide-users] RE: Tiffs and MGOS 2.01
>> Did you specify a coordinate system override on your Data connection
so that
>> when you add the layer to the map it knows what CS it's in?
>> Dave
>> Pendergraft
>> Sent: Wednesday, October 01, 2008 4:56 PM
>> To: mapguide-users at lists.osgeo.org
>> Subject: [mapguide-users] Tiffs and MGOS 2.01
>> I'm having trouble with TIFF's in MGOS 2.01. I'm using Mapguide
Studio 2009
>> and the GDAL provider. I can create a data resource from a directory
>> containing 4 tiffs (downloaded from USGS National Map - NED Imagery).
And
>> I'm able to create a layer, and view the tiff data in the layer
preview.
>> Everything is fine until I add it into my map. It doesn't show up at
all.
>> I have even made another map with just the tiff layer, and zoomed way
out.
>> Nothing. I have tried different coordinate systems, and I'm
currently using
>> the LL83 (which is the same as the tiff coordinate system) and I've
even
>> plugged in the lat/longs from the tiff's lower/upper corners into the
map.
>> Am I missing something here?
>> Thanks.
>> -Mark Pendergraft
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> Zac Spitzer -
> http://zacster.blogspot.com (My Blog)
> +61 405 847 168
Zac Spitzer -
+61 405 847 168
