[mapguide-users] StatusScale issue in scale ranges
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Sun Oct 5 06:24:28 EDT 2008
Can you clarify the problem a bit?
If you have a layer with scale ranges:
0-2000 : Red dots
2001-Infinite : Blue dots
Does it change from blue to red if you type in "2000" in the status bar
at the bottom?
Does it change if you use the slider (to the same range)?
Does it change if you drag a rectange (to the same range)?
(The change is expected behavior)
If you have ranges:
0-2000
4000-Infinite
The layer will be invisible in the range [2001-3999], which is correct
behavior.
Regards, Kenneth Skovhede, GEOGRAF A/S
Rodolfo Moreno skrev:
> Hi all,
> I got an issue in mapguide 2.0.1.
> Layers with different scale ranges become invisible when you do zoom in with
> the StatusScale until to achieve one of the scale ranges.
> It happens with any of the viewers (AJAX, DWF or FUSION), which is why I
> think that the problem is the mapguide server.
> I don't know whether this issue has been solved in the 2.0.2 version
> I would like to know whether someone has gotten the same problem.
> Regards
> Rodolfo Moreno
> CivilEng
