[mapguide-users] ArcSDE FDO sucks !!!
Rock Beans
rockbeans at gmail.com
Mon Oct 6 16:20:02 EDT 2008
Is the SDE server on the same network or are you hitting a remote
server? I have seen slow response when accessing a remote server
through the net.
On Mon, Oct 6, 2008 at 1:10 PM, Jason Birch <Jason.Birch at nanaimo.ca> wrote:
> You may be asking on the wrong list if you want the FDO folks to
> respond. Though I'm sure that some of them hang out here from time to
> time, fdo-users is a better place. Might want to use a less
> inflammatory subject line though :)
> The problem may not be with the SDE provider though; I wonder if it is
> the same problem with initial schema load as has been seen with the
> RDBMS providers. Does performance decrease as the number of tables
> stored in the SDE increases, or is it consistently slow?
> The best way to get this fixed is to clearly describe the problem,
> preferably with test data, in a Trac ticket. Just saying that it is
> slow is not giving the developers enough to chew on.
> Jason
> -----Original Message-----
> From: shreepad Ranadive
> Subject: Re: [mapguide-users] ArcSDE FDO sucks !!!
> I found the same issue. the new fdos are bit slow with sde 9.1 /9.2
> i think some one from FDO team should take a look at it seriously
> FDO team : please have some reply to this request
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
