[mapguide-users] ArcSDE FDO sucks !!!
shreepad Ranadive shreepadr at valuecad.com
Thu Oct 9 14:09:05 EDT 2008
the patch for ArcSDE !!  is talked in one  of the email links bellow. please
let me know where can i download that and give it a shot
shreepad
Robert Fortin wrote:
> Shreepad,
> As Jason said, it is not clear that this is a provider issue.  One issue
> was identified sometime ago related to invalid coordinate system handling
> in MG.  This issue was slowing down performance when coordinates system
> couldn't be mapped.  This was fixed in the recent MG code stream but I'm
> not sure it was backported in the code stream where you are seeing this
> problem.  I'm trying to contact the developer who look into this issue and
> see if we can get a hotfix or patch to try out.
> I'm not sure that it will actually fix the problem you are seeing but it
> doesn't cost much trying it out.
> I'll keep you posted.
> RF
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of shreepad
> Ranadive
> Sent: Monday, October 06, 2008 5:28 PM
> To: mapguide-users at lists.osgeo.org
> Subject: RE: [mapguide-users] ArcSDE FDO sucks !!!
> thanks jason
> i will create a trac for this on fdo site.
> I have tested this with  couple layers with new schema created its still
> slow.
> let me create trac to have it looked at by developers
> thanks
> shreepad
> JasonBirch wrote:
>> You may be asking on the wrong list if you want the FDO folks to
>> respond.  Though I'm sure that some of them hang out here from time to
>> time, fdo-users is a better place.  Might want to use a less
>> inflammatory subject line though :)
>> The problem may not be with the SDE provider though; I wonder if it is
>> the same problem with initial schema load as has been seen with the
>> RDBMS providers.  Does performance decrease as the number of tables
>> stored in the SDE increases, or is it consistently slow?
>> The best way to get this fixed is to clearly describe the problem,
>> preferably with test data, in a Trac ticket.  Just saying that it is
>> slow is not giving the developers enough to chew on.
>> Jason
>> From: shreepad Ranadive
>> Subject: Re: [mapguide-users] ArcSDE FDO sucks !!!
>> I found the same issue. the new fdos are bit slow with sde 9.1 /9.2
>> i think some one from FDO team should take a look at it seriously
>> FDO team : please have some reply to this request
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> Shreepad Ranadive
> Direcotor , Application Development
> ValueCAD
> 444 Natoma St
> Sanfrancisco,CA 94103
> http://www.nabble.com/ArcSDE-FDO-sucks-%21%21%21-tp19832086p19846802.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
Shreepad Ranadive
ValueCAD
444 Natoma St
View this message in context: http://www.nabble.com/ArcSDE-FDO-sucks-%21%21%21-tp19832086p19904277.html
