[mapguide-users] SQL Import Spatial Data
Rock Beans
rockbeans at gmail.com
Fri Oct 10 11:02:00 EDT 2008
I had the pleasure of working with a beta installer of the Autodesk
SQL spatial provider and I was able to bulk copy from Map3D and create
maps in MapGuide using Studio 2009. I did see an issue with joining
external data one-to-many as it only returned one-to-one not sure if
this was fixed. I have not received any updates. The MapGuide
performance was great overall with my simple 5 layer and one inner
join themed map.
On Thu, Oct 9, 2008 at 10:50 AM, Jason Birch <Jason.Birch at nanaimo.ca> wrote:
> Yes, using FME. That part was pretty darn easy. You may also have some
> success (not with the DWG part) using Jackie's FDO Toolbox or SL-King's
> FDO2FDO.
> I found SQL 2008 to be relatively fast (compared to other RDBMS) but the
> lack of curve support and its insistence on valid OGC geometry were
> showstoppers for me.
> Jason
> From: Greenhough, Jamie
> Subject: [mapguide-users] SQL Import Spatial Data
> Does anyone have experience with importing spatial data to SQL 2008?
> Specifically SHP/DWG -> SQL.
> We are exploring the development effort and performance of using unmanaged
> SHP/DWG files with alias' vs. importing these files into SQL2008 and using
> FDO.
> Any input is appreciated, thanks.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
