[mapguide-users] installing mapguide on server with php already on it
Ed Jobe ed57gmc-bus at yahoo.com
Fri Oct 10 12:56:49 EDT 2008
See this post.
http://www.nabble.com/forum/ViewPost.jtp?post=19729894&framed=y
kawalski wrote:
> ok, i have at least been able to get to the login screen but get a 500
> error when i try to log in.  i have put the phpinfo() in the login php
> page and everything is pointing to the correct directories.
> thanks
> Dave Wilson-3 wrote:
>> Do a diff between the MapGuide php.ini and your existing on to see the
>> changes that are required. There are only a couple of changes. You will
>> also have to copy the additional php extension files included for
>> mapguide to your directory. Again a diff between the directories might be
>> the easiest way to go. I just don't know all the files off the top of my
>> head.
>> You then have to change the isapi mapping on the mapguide virtual
>> directory in IIS to point to your instance.
>> I think that's it.
>> Dave
>> -----Original Message-----
>> From: mapguide-users-bounces at lists.osgeo.org
>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of kawalski
>> Sent: Thursday, October 09, 2008 8:39 AM
>> To: mapguide-users at lists.osgeo.org
>> Subject: RE: [mapguide-users] installing mapguide on server with php
>> already on it
>> so, if i remove the php directory under the mapguide directories and
>> remove
>> the instance in PATH, then mapguide would look at the other php i already
>> have installed?  is there anything else that would need to be done to
>> make
>> mapguide look to the other php?
>> thanks
>>> Because you are using the same version, whichever is first in the path
>>> is
>>> likely to get used to set the php.ini when IIS loads. I don't believe
>>> you
>>> will get both of them to work. The registry entry also only points to
>>> one
>>> of the instances so again it's not really designed to allow both. A
>>> phpinfo page might help indicate which instance is getting loaded.
>>> You will likely have to decide which instance of PHP you wish to use and
>>> configure it for all the applications you need unless someone else has
>>> discovered a way to do this without recompiling php for their needs.
>>> Regards,
>>> Dave
>>> Sent: Thursday, October 09, 2008 7:17 AM
>>> already on it
>>> i have php 5.2.4 installed on the server.  i am on Windows.  both phps
>>> are
>>> in
>>> the PATH variable.
>>>> What version of PHP is already installed. MapGuide only works with the
>>>> installed version. PHP also doesn't play well side by side or support
>>>> dual
>>>> instances of near versions out of the box. This is documented on the
>>>> PHP
>>>> site. http://us.php.net/configuration
>>>> Are you installing on Windows or Linux.
>>>> Previous discussions in the list recommend adding the MapGuide PHP
>>>> install
>>>> directory to your system path (Windows).
>>>> You can also check your registry to see if the HKLM...entry points to
>>>> the
>>>> installed directory (Windows).
>>>> Dave
>>>> Sent: Wednesday, October 08, 2008 3:19 PM
>>>> Subject: [mapguide-users] installing mapguide on server with php
>>>> already
>>>> on it
>>>> i am trying to install mapguide on a server that is running IIS and
>>>> already
>>>> has php installed.  i can not get the mapguide php pages to work.  i
>>>> can't
>>>> get to the login page for adimistrator.  i have changed settings in IIS
>>>> a
>>>> number of times to get .php to point to either of the php directories.
>>>> when
>>>> i removed the original php i could not get the other php pages to work
>>>> by
>>>> pointing them to the mapguide version.  how do you get the 2 php's to
>>>> play
>>>> together?
>>>> View this message in context:
>>>> http://www.nabble.com/installing-mapguide-on-server-with-php-already-on-it-tp19880766p19880766.html
>>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>>> _______________________________________________
>>>> mapguide-users mailing list
>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>> http://www.nabble.com/installing-mapguide-on-server-with-php-already-on-it-tp19880766p19898310.html
>> http://www.nabble.com/installing-mapguide-on-server-with-php-already-on-it-tp19880766p19900334.html
View this message in context: http://www.nabble.com/installing-mapguide-on-server-with-php-already-on-it-tp19880766p19922108.html
