[mapguide-users] SQL Import Spatial Data
Jason Birch Jason.Birch at nanaimo.ca
Fri Oct 10 14:22:33 EDT 2008
Ah.  Yes, I think MapGuide's authentication is fine, but the
authorization model is a bit dysfunctional.
Active Directory / LDAP are not directly supported, so you'd have to
test group membership in your application and map this to the
appropriate RO/RW users on the MapGuide server, and make sure that
everything goes over SSL.
This doesn't isolate you from poorly-behaved users or CSS attacks
stealing a session key and using it directly against the web tier
though.  I think the only way of dealing with this particular issue is
fixing the MapGuide security model.
Jason
Subject: Re: [mapguide-users] SQL Import Spatial Data
AD is Active Directory. I was planning on using it for authentication. I
forgot who it was that said it, but they felt that mg's security was
"broken".
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20081010/97309e4f/attachment.html
