[mapguide-users] installing mapguide on server with php already
on it
kawalski
jhagedorn at bannerassociates.com
Fri Oct 10 16:18:53 EDT 2008
in ticket #454, it says to Build a copy of php_MapGuideApiEnvConfig.dll from
SVN . i'm sorry but i don't know how to build a dll or what SVN is. any
help?
thanks
kawalski
Ed Jobe wrote:
> >this shouldn't be this difficult
> With open source like linux, etc., it often is. ;-) Configuration can
> be a bear.
> Ed Jobe
> ----- Original Message ----
> From: kawalski <jhagedorn at bannerassociates.com>
> To: mapguide-users at lists.osgeo.org
> Sent: Friday, October 10, 2008 12:47:26 PM
> Subject: Re: [mapguide-users] installing mapguide on server with php
> already on it
> i put the dll's in the ext directory and put the reference in the
> php.ini. i
> have used the installers to put mapguide on. the instructions are for
> building everything from scratch and is done with the installers. i think
> i
> have everything done with the config of IIS. the viteral directories are
> created with the installers and have checked that the .php looks at the
> php
> on c:\program files\php. this shouldn't be this difficult.
> thanks
> kawalski
> Ed Jobe wrote:
>> You need to install the dll mentioned and configure php.ini according to
>> those directions. Also, if it can't find php_mapguide.dll, you need to
>> follow the instructions from the download site for configuring iis.
>> Ed Jobe
>> Sent: Friday, October 10, 2008 11:40:37 AM
>> Subject: RE: [mapguide-users] installing mapguide on server with php
>> already on it
>> that post really didn't do anything for me. everything is on one
>> machine. i
>> have got the mapguide looking at the php that was on the machine before.
>> i
>> have phpinfo() on the login page and it shows that it is looking at the
>> right php. i have removed the php in path that had it going to the
>> mapguide
>> directory. i have make sure that the mapguide server is running. when i
>> restart IIS and go tothe login.php, the first thing i get is an error box
>> that says it can't find the php_MapGuideApi.dll. it is in the ext
>> directory
>> under the php directory. the extention_dir points to the ext directory
>> under the C:\program files\php\ext. so what is the next step? i even
>> tried
>> yesterday out of frustration to remove everything and installed mapguide
>> with the apache and i couldn't even get the login.php to come up. i'm
>> further ahead so far with the IIS install but i have been dinking with
>> this
>> now for the better part of 5 days. the demo i seen at the MN GIS/LIS
>> conference last week made this look so easy.
>> thanks
>> kawalski
>> Ed Jobe wrote:
>>> See this post.
>>> http://www.nabble.com/forum/ViewPost.jtp?post=19729894&framed=y
>>> kawalski wrote:
>>>> ok, i have at least been able to get to the login screen but get a 500
>>>> error when i try to log in. i have put the phpinfo() in the login php
>>>> page and everything is pointing to the correct directories.
>>>> thanks
>>>> Dave Wilson-3 wrote:
>>>>> Do a diff between the MapGuide php.ini and your existing on to see the
>>>>> changes that are required. There are only a couple of changes. You
>>>>> will
>>>>> also have to copy the additional php extension files included for
>>>>> mapguide to your directory. Again a diff between the directories might
>>>>> be the easiest way to go. I just don't know all the files off the top
>>>>> of
>>>>> my head.
>>>>> You then have to change the isapi mapping on the mapguide virtual
>>>>> directory in IIS to point to your instance.
>>>>> I think that's it.
>>>>> Dave
>>>>> -----Original Message-----
>>>>> From: mapguide-users-bounces at lists.osgeo.org
>>>>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of kawalski
>>>>> Sent: Thursday, October 09, 2008 8:39 AM
>>>>> already on it
>>>>> so, if i remove the php directory under the mapguide directories and
>>>>> remove
>>>>> the instance in PATH, then mapguide would look at the other php i
>>>>> already
>>>>> have installed? is there anything else that would need to be done to
>>>>> make
>>>>> mapguide look to the other php?
>>>>> thanks
>>>>>> Because you are using the same version, whichever is first in the
>>>>>> path
>>>>>> is
>>>>>> likely to get used to set the php.ini when IIS loads. I don't believe
>>>>>> you
>>>>>> will get both of them to work. The registry entry also only points to
>>>>>> one
>>>>>> of the instances so again it's not really designed to allow both. A
>>>>>> phpinfo page might help indicate which instance is getting loaded.
>>>>>> You will likely have to decide which instance of PHP you wish to use
>>>>>> and
>>>>>> configure it for all the applications you need unless someone else
>>>>>> has
>>>>>> discovered a way to do this without recompiling php for their needs.
>>>>>> Regards,
>>>>>> Dave
>>>>>> Sent: Thursday, October 09, 2008 7:17 AM
>>>>>> already on it
>>>>>> i have php 5.2.4 installed on the server. i am on Windows. both
>>>>>> phps
>>>>>> are
>>>>>> in
>>>>>> the PATH variable.
>>>>>>> What version of PHP is already installed. MapGuide only works with
>>>>>>> the
>>>>>>> installed version. PHP also doesn't play well side by side or
>>>>>>> support
>>>>>>> dual
>>>>>>> instances of near versions out of the box. This is documented on the
>>>>>>> PHP
>>>>>>> site. http://us.php.net/configuration
>>>>>>> Are you installing on Windows or Linux.
>>>>>>> Previous discussions in the list recommend adding the MapGuide PHP
>>>>>>> install
>>>>>>> directory to your system path (Windows).
>>>>>>> You can also check your registry to see if the HKLM...entry points
>>>>>>> to
>>>>>>> the
>>>>>>> installed directory (Windows).
>>>>>>> Dave
>>>>>>> kawalski
>>>>>>> Sent: Wednesday, October 08, 2008 3:19 PM
>>>>>>> Subject: [mapguide-users] installing mapguide on server with php
>>>>>>> already
>>>>>>> on it
>>>>>>> i am trying to install mapguide on a server that is running IIS and
>>>>>>> already
>>>>>>> has php installed. i can not get the mapguide php pages to work. i
>>>>>>> can't
>>>>>>> get to the login page for adimistrator. i have changed settings in
>>>>>>> IIS a
>>>>>>> number of times to get .php to point to either of the php
>>>>>>> directories.
>>>>>>> when
>>>>>>> i removed the original php i could not get the other php pages to
>>>>>>> work
>>>>>>> by
>>>>>>> pointing them to the mapguide version. how do you get the 2 php's
>>>>>>> to
>>>>>>> play
>>>>>>> together?
>>>>>>> View this message in context:
>>>>>>> http://www.nabble.com/installing-mapguide-on-server-with-php-already-on-it-tp19880766p19880766.html
>>>>>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>>>>>> _______________________________________________
>>>>>>> mapguide-users mailing list
>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>>>>> http://www.nabble.com/installing-mapguide-on-server-with-php-already-on-it-tp19880766p19898310.html
>>>>> http://www.nabble.com/installing-mapguide-on-server-with-php-already-on-it-tp19880766p19900334.html
>> http://www.nabble.com/installing-mapguide-on-server-with-php-already-on-it-tp19880766p19923801.html
> http://www.nabble.com/installing-mapguide-on-server-with-php-already-on-it-tp19880766p19924930.html
View this message in context: http://www.nabble.com/installing-mapguide-on-server-with-php-already-on-it-tp19880766p19925409.html
