[mapguide-users] Change map scale or get min and max scale from
layer
Lukas Hybner
hybner at atlas.cz
Tue Oct 14 07:12:57 EDT 2008
Hi all,
I have a problem when I show tree of layers. I need to know if the layer
is Visible or not.
For Example client send scale=5000000 and some layers is visible from 1
to 4000. When I want to know if the layers is visible, I use method
isVisible(). This method return always true because map.getViewScale()
returns 1.0 (not 5000000).
My code is (in jsp):
String mapDefinition = "some map definition";
MgMap map = new MgMap();
MgResourceIdentifier resId = new MgResourceIdentifier(mapDefinition);
String mapName = resId.GetName();
map.Create(resourceSrvc, resId, mapName);
MgGeometryFactory factory = new MgGeometryFactory();
MgCoordinate centerCoord = factory.CreateCoordinateXY(centerx,centery);
//here is scale property from client
MgByteReader mgImage = renderingSrvc.RenderMap( map, null, centerCoord,
scale,width, height, color, "JPG" );
out.println(map.GetViewScale()); //returns 1.0
MgLayerCollection layers = map.GetLayers();
for (int i = 0; i < layers.GetCount(); ++i)
out.println( (layers.GetItem(i).isVisible ? "on" : "off") );
//this write on
How can I change scale in object map? Or is some other solution? Or can
I read from layer object min and max scale?
Lukas Hybner
