[mapguide-users] Adding a point to a map... PLZ Help!!! (.NET -
C#)
Galois
amihalas at yahoo.gr
Wed Oct 15 10:15:27 EDT 2008
Maybe I'm stupid....
I cannot do it work. I have reconstruct the whole thing, but the new Layer
doesn't appear in the page.
I followed the Dev's Guide in order to create a Layer and add it in the map
but nothing.
Basically, I added these three functions. I really would appreciate if u
could give me some help..
public MgLayer addLayerRsc2Map(MgResourceIdentifier layerResId,
MgResourceService resourceSrvc, string layerName, string layerLegendLabel,
MgMap map)
//MgLayer newLayer = new MgLayer(layerResId, resourceSrvc);
MgLayer newLayer = new MgLayer(layerResId , resourceSrvc);
//Add the new layer to the map's layer collection
newLayer.SetName(layerName);
newLayer.SetVisible(true);
newLayer.SetLegendLabel(layerLegendLabel);
newLayer.SetDisplayInLegend(true);
MgLayerCollection layerCollection = map.GetLayers();
if( !layerCollection.Contains(layerName) )
//Insert the new layer to position 0 so it is at
//the top of the drawing order
layerCollection.Insert(0,newLayer);
MgLayerGroupCollection skata = map.GetLayerGroups();
return newLayer;
public MgLayer addLayerDef2Map(string layerDefinition, string layerName,
string layerLegendLabel, string sessionId, MgResourceService resourceSrvc,
MgMap map )
// Adds the layer definition (XML) to the map.
// Returns the layer.
//Validate the XML.
XmlDocument domDocument = new XmlDocument();
domDocument.LoadXml(layerDefinition);
domDocument.PreserveWhitespace = true;
MemoryStream stream = new System.IO.MemoryStream();
domDocument.Save(stream);
Byte[] byteArray = stream.ToArray();
string outerXml = System.Text.Encoding.UTF8.GetString(byteArray, 0,
byteArray.Length);
byteArray = System.Text.Encoding.UTF8.GetBytes(outerXml);
//Save the new layer definition to the Session.
MgByteSource byteSource = new MgByteSource(byteArray ,
byteArray.Length);
byteSource.SetMimeType(MgMimeType.Xml);
MgResourceIdentifier resourseId = new
MgResourceIdentifier("Session:" + map.SessionId + "//" + layerName + "." +
MgResourceType.LayerDefinition);
// Set the map with the new resource
resourceSrvc.SetResource(resourseId, byteSource.GetReader(), null);
MgLayer newLayer = addLayerRsc2Map(resourseId, resourceSrvc,
layerName, layerLegendLabel, map);
return newLayer;
public void addLayer2Group(MgLayer layer, string layerGroupName, string
layerGroupLegendLabel, MgMap map)
// Adds a layer to a layer group. If necessary, it creates
// the layer group.
//Get the layer group
MgLayerGroup layerGroup;
MgLayerGroupCollection layerGroupCollection = map.GetLayerGroups();
if( layerGroupCollection.Contains(layerGroupName) )
layerGroup = layerGroupCollection.GetItem(layerGroupName);
else
//It does not exist, so create it.
layerGroup = new MgLayerGroup(layerGroupName);
layerGroup.SetVisible(true);
layerGroup.SetDisplayInLegend(true);
layerGroup.SetLegendLabel(layerGroupLegendLabel);
layerGroupCollection.Add(layerGroup);
//Add the layer to the group.
layer.SetGroup(layerGroup);
Kenneth Skovhede, GEOGRAF A/S wrote:
> Did you look at the buffer sample code in the AJAX viewer?
> It does exactly what is required, besides inserting your points.
> About your code:
> You do not use the "resourceIdentifier" variable, which means your layer
> might reference something else.
> You save the layers to the regular repository, which is fine, but each
> use will overwrite the previous copy, making
> it impossible to reliably serve more than one user.
> You do not add the layer to the runtime map, and you do not save the
> runtime map.
> You write: "I just want to display them".
> Well, MapGuide works by displaying data from a FeatureSource, styled
> through a LayerDefinition.
> You cannot insert data in the LayerDefinition, it must be in a
> FeatureSource.
> If you insert the data in an existing FeatureSource, with an existing
> layer, that is fine too, but I cannot guess that is what you want.
> You did not mention an Xml file with points before, just a single point.
> Depending on your data, you may want to insert them into a database
> (like Sqlite or Access), or into an SDF file.
> If you choose the database version, your FeatureSource can be of type
> ODBC.
> If you use a database, you can insert the points using regular SQL
> queries against the database.
> If the points are persistent (that is, not tied to a particular users
> map, like session values),
> you can just create a FeatureSource + Layer through Maestro or Studio
> without requirering any code.
> If you are looking to create something similar to "Points of interrest"
> with a nice little flag, you might
> consider using OpenLayers instead of the AJAX viewer:
> http://www.openlayers.org/
> http://www.openlayers.org/dev/examples/georss-markers.html
> (OpenLayers also supports MapGuide as the backend server)
> Regards, Kenneth Skovhede, GEOGRAF A/S
> Galois skrev:
>> First of all, thank u fro your reply.
>> I don't get why should I create a temp layer.
>> I have some coordinates in an XML file, and I just want to display them
>> on
>> an existing layer.
>> Though I tried to create a new layer, it does not appear in my maps
>> layers.
>> That's what I did...
>> MgResourceIdentifier resourceIdentifier = new
>> MgResourceIdentifier("Library://GoSpatial/Data/airports.FeatureSource");
>> MgResourceIdentifier layerResId = new
>> MgResourceIdentifier("Library://GoSpatial/Layers/TmpLayer.LayerDefinition");
>> string layerDefinition =
>> File.ReadAllText("C:/Inetpub/wwwroot/iwaygis/TmpLayer.LayerDefinition.xml");
>> MgByteReader reader = new MgByteReader(layerDefinition,
>> "text/xml");
>> resourceSrvc.SetResource(layerResId, reader, null);
>> tmpLayer = new MgLayer(layerResId, resourceSrvc);
>> tmpLayer.SetName("TempLayer");
>> tmpLayer.SetLegendLabel("TempLayer");
>> tmpLayer.SetDisplayInLegend(true);
>> tmpLayer.SetSelectable(true);
>> MgLayerCollection layers = map.GetLayers();
>> layers.Insert(0, tmpLayer);
>> tmpLayer.SetVisible(true);
>> tmpLayer.ForceRefresh();
>> Thx!
>>> A few steps are involved:
>>> 1. Create a temporary featuresource
>>> 2. Create a temporary layer to display the features
>>> 3. Insert the temporary layer into the runtime map
>>> The buffer files in the MapGuide viewer has template code for all three
>>> steps.
>>> All steps are explained in the Developer Guide (PDF version at least).
>>> You might also want to look here:
>>> http://trac.osgeo.org/mapguide/wiki/CodeSamples/ASP.Net/ScribbleApp
>>> Galois skrev:
>>>> Hello,
>>>> I´m trying to add a point to a map but I have no idea how to it.
>>>> I have declare the map object, and also I create a point with it's
>>>> coordinates.
>>>> But I don't know what is the next step that I have to do...
>>>> The code follows....
>>>> public partial class _Default : System.Web.UI.Page
>>>> public string sessionId;
>>>> public string webLayout;
>>>> protected void Page_Load(object sender, EventArgs e)
>>>> string physicalPath = @"C:\Program
>>>> Files\MapGuideOpenSource\WebServerExtensions\www\webconfig.ini";
>>>> try
>>>> MapGuideApi.MgInitializeWebTier(physicalPath);
>>>> passAndSession();
>>>> //Associate a session ID with the MgSiteConnection Object
>>>> MgUserInformation userInfo_new = new
>>>> MgUserInformation(sessionId);
>>>> MgSiteConnection siteConnection = new MgSiteConnection();
>>>> siteConnection.Open(userInfo_new);
>>>> MgResourceService resourceSrvc =
>>>> (MgResourceService)siteConnection.CreateService(MgServiceType.ResourceService);
>>>> MgMap map = new MgMap(siteConnection);
>>>> webLayout =
>>>> "Library://GoSpatial/Web+Layouts/Autostrada+Brescia+Padova+Map.WebLayout";
>>>> MgResourceIdentifier resId = new
>>>> MgResourceIdentifier("Library://GoSpatial/Maps/Italy
>>>> Map.MapDefinition");
>>>> String mapName = resId.GetName();
>>>> MgResourceIdentifier mapStateId = new
>>>> MgResourceIdentifier("Session:" + sessionId + "//" + mapName + "." +
>>>> MgResourceType.Map);
>>>> map.Create(resourceSrvc, resId, mapName);
>>>> map.Save(resourceSrvc, mapStateId);
>>>> map.Open(resourceSrvc, mapName);
>>>> createPoint();
>>>> catch (Exception ex)
>>>> throw (ex);
>>>> public string passAndSession()
>>>> MgUserInformation userInfo = new
>>>> MgUserInformation("Administrator",
>>>> "admin");
>>>> MgSite site = new MgSite();
>>>> site.Open(userInfo);
>>>> sessionId = site.CreateSession();
>>>> return sessionId;
>>>> public MgPoint createPoint()
>>>> MgGeometryFactory geometryFactory = new MgGeometryFactory();
>>>> MgCoordinateXY coordinate = (MgCoordinateXY)
>>>> geometryFactory.CreateCoordinateXY(10.913161, 45.408046);
>>>> MgPoint point = geometryFactory.CreatePoint(coordinate);
>>>> return point;
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://www.nabble.com/Adding-a-point-to-a-map...-PLZ-Help%21%21%21-%28.NET---C-%29-tp19954532p19994399.html
