[mapguide-users] Print Layout - 2 questions...
stoff
mail at effing.org
Thu Oct 16 05:37:42 EDT 2008
Hi Kenneth, hi Warren!
...just to be sure:
Is it true that the Mapguide Studio Printlayouts are only to use
within the dwf viewer (and its activeX-features)?
To have a customized printlayout in the mapguide ajax standard viewer
I have to modify the printablepage.templ?
And this pertains topobase web in the same manner, doesn't it?
Just a big suprise, because the Users Guide does not really gives hints on
this ...
Best regards and thank you in advance,
stoff javascript:Nabble.smiley('anim_confused.gif',':confused:')
Is it okay, to ask this here or do I have to ask it only in the autodesk
discussion group?
Warren Medernach wrote:
> Perfect!
> Thanks for the info Kenneth.
> Warren M
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Kenneth
> Skovhede, GEOGRAF A/S
> Sent: Friday, October 03, 2008 11:54 AM
> To: MapGuide Users Mail List
> Subject: Re: [mapguide-users] Re: Print Layout - 2 questions...
> Not sure if he got the answers, but here they are:
> 1. You must change it in ajaxmappane.templ (line 293):
> Look for:
> var us = true;
> and change to:
> var us = false;
> You have to change this every time update your MapGuide installation.
> 2. There is no built in way to do this, you must modify
> printablepage.templ.
> Its a HTML file that gets sent to the browser with the map items
> injected.
> You can set a logo anywhere on the page using some html:
> If you want different printable pages for different solutions, you have
> to modify
> at least printablepageui.templ.
> Again, you have to change this every time update your MapGuide
> installation.
> The files I mention are all located in:
> C:\Program
> files\MapGuideOpenSource2.0\WebServerExtensions\www\viewerfiles
> Regards, Kenneth Skovhede, GEOGRAF A/S
> Warren Medernach skrev:
> Hi Andrew,
> Were you ever able to resolve this print layout issue?
> Warren M
> I've got 2 questions about PrintLayouts....1) How do I make my
> units
> metres? I've got >every instance of <units> set to metres in my
> PrintLayout, and yet my scale bar insists >that the units are feet. 2)
> How the heck do you get a custom logo?? It seems so simple, >but I can't
> get it to work for the life of me....I've got a symbol library called
> "Logo", and in it there is one symbol called "Gemlogo-smaller".
> I've
> tried all sorts of >variations on ResourceIDs, but can't get it.
> Andrew
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
:confused:
View this message in context: http://www.nabble.com/Re%3A-Print-Layout---2-questions...-tp19801245p20010308.html
