[mapguide-users] Adding a point to a map... PLZ Help!!! (.NET -C#)
Galois amihalas at yahoo.gr
Thu Oct 16 05:59:13 EDT 2008
No, I just was informed that all the points we have are generated
dynamically.
For example from the position of a car on the highway...
I really don't know what I am doing wrong.
Galois wrote:
> I have a DB with coordinates, but how am I going to put these coordinates
> in a layer. Even from AutoDesk...?
> Kenneth Skovhede, GEOGRAF A/S wrote:
>> I still can't tell which of the two scenarios you are aiming at.
>> So you have a highway, and some points on the highway.
>> I'm thinking that the points should be created before the user starts to
>> do anything.
>> Does it make sense to convert the data into a database with X and Y
>> columns, before even thinking about what MapGuide does?
>> You can make a little batch job that updates the database if you prefer,
>> still without use of MapGuide.
>> Once you have such a database, set it up in Studio or Maestro like a
>> regular layer.
>> Add the layer to the map, but make it invisible if you only want to show
>> it in some cases.
>> Now, during runtime, you can create a copy of the LayerDefinition, and
>> insert a "filter" on the layer.
>> This will allow you to control what points a specific user sees.
>> Now save this copy of the LayerDefinition to the Session store.
>> The update the layer in the runtime map to point to the Session based
>> LayerDefinition, and set the layer visible.
>> Now save the runtime map, and issue a refresh on the client.
>> I can't tell from your code fragments what goes wrong, but there is no
>> map.Save(...) call present, which is
>> how you would save the changes to the map. There is no
>> "getMap().Refresh()" call present, which must be issued
>> on the client in Javascript.
>> Regards, Kenneth Skovhede, GEOGRAF A/S
>> Galois skrev:
>>> You are wright about the confusion...
>>> Anyway, the scenario is the following:
>>> I have a map with the Highway of two Italian Cities.
>>> Firstly, I would like to display some points of interest on that map.
>>> Those points I have them in an XML file.
>>> So, my problem till now, is that I add a new layer on my map ( I see in
>>> debug mode that my map's Layers has increased ) but this layer doesn't
>>> appear in the page.
>>> If I solve this thing I'll try to add the points to this layer.
>>> Also, keep in mind that these points of interest, there might be static
>>> or
>>> not.
>>> This means that there is no point to create all this from Autodesk
>>> manually...
>>> Thank you (both) for the help!
>>>> I agree with Maksim, there seems to be some confusion as to what you
>>>> want to do.
>>>> There are two basic scenarios:
>>>> 1. You want to display some points based on context.
>>>> An example would be searching for hotels in a certain price interval,
>>>> and the opening a map with the hotels shown.
>>>> 2. You want to display a number of points, but the data changes more or
>>>> less frequently.
>>>> An example of this would be position of vehicles.
>>>> A combination would be to show the position of vehicles that are using
>>>> diesel engines.
>>>> Could you elaborate on what your scenario is like?
>>>> Maksim Sestic skrev:
>>>>> Hmm, if you're attending to batch-process large number of points
>>>>> (along
>>>>> with
>>>>> attached data) then web service calling FDO directly will do it much
>>>>> more
>>>>> efficiently, since you can preset it on server side to poke exact
>>>>> datastore/schema (thus skipping enumeration). Especially if you're
>>>>> planning
>>>>> to parse some client-side file holding actual information. Other way
>>>>> round
>>>>> you'll be making too many client-server roundtrips.Of couse, it all
>>>>> depends
>>>>> on the overall setup...
>>>>> -----Original Message-----
>>>>> From: mapguide-users-bounces at lists.osgeo.org
>>>>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Galois
>>>>> Sent: Wednesday, October 15, 2008 16:29
>>>>> To: mapguide-users at lists.osgeo.org
>>>>> Subject: RE: [mapguide-users] Adding a point to a map... PLZ Help!!!
>>>>> (.NET
>>>>> -C#)
>>>>> This is not a solution, cause at the feature, I'll have lot of XML
>>>>> files
>>>>> and
>>>>> the code will have to work in order to put all the interest points
>>>>> automatic
>>>>> on the map....
>>>>> ThanX anyway :-D
>>>>> Maksim Sestic wrote:
>>>>>> If the MG->Datastore approach is making you headaches, why don't you
>>>>>> directly access the datastore (i.e. via FDO if it's managed after
>>>>>> all)
>>>>>> and store the point there "manually"? Of course, if you're poking it
>>>>>> from a client you'll have to establish a web service to do the job on
>>>>>> the server side. And don't forget to call MG refresh method from
>>>>>> JavaScript once you have that point within a datastore.
>>>>>> Regards,
>>>>>> Maksim Sestic
>>>>>> Sent: Wednesday, October 15, 2008 16:15
>>>>>> Subject: Re: [mapguide-users] Adding a point to a map... PLZ Help!!!
>>>>>> (.NET
>>>>>> -C#)
>>>>>> Maybe I'm stupid....
>>>>>> I cannot do it work. I have reconstruct the whole thing, but the new
>>>>>> Layer doesn't appear in the page.
>>>>>> I followed the Dev's Guide in order to create a Layer and add it in
>>>>>> the map but nothing.
>>>>>> Basically, I added these three functions. I really would appreciate
>>>>>> if
>>>>>> u could give me some help..
>>>>>> public MgLayer addLayerRsc2Map(MgResourceIdentifier layerResId,
>>>>>> MgResourceService resourceSrvc, string layerName, string
>>>>>> layerLegendLabel, MgMap map)
>>>>>>         //MgLayer newLayer = new MgLayer(layerResId, resourceSrvc);
>>>>>>         MgLayer newLayer = new MgLayer(layerResId , resourceSrvc);
>>>>>>         //Add the new layer to the map's layer collection
>>>>>>         newLayer.SetName(layerName);
>>>>>>         newLayer.SetVisible(true);
>>>>>>         newLayer.SetLegendLabel(layerLegendLabel);
>>>>>>         newLayer.SetDisplayInLegend(true);
>>>>>>         MgLayerCollection layerCollection = map.GetLayers();
>>>>>>         if( !layerCollection.Contains(layerName) )
>>>>>>             //Insert the new layer to position 0 so it is at
>>>>>>             //the top of the drawing order
>>>>>>             layerCollection.Insert(0,newLayer);
>>>>>>         MgLayerGroupCollection skata = map.GetLayerGroups();
>>>>>>         return newLayer;
>>>>>>     public MgLayer addLayerDef2Map(string layerDefinition, string
>>>>>> layerName, string layerLegendLabel, string sessionId,
>>>>>> MgResourceService resourceSrvc, MgMap map )
>>>>>>         // Adds the layer definition (XML) to the map.
>>>>>>         // Returns the layer.
>>>>>>         //Validate the XML.
>>>>>>         XmlDocument domDocument = new XmlDocument();
>>>>>>         domDocument.LoadXml(layerDefinition);
>>>>>>         domDocument.PreserveWhitespace = true;
>>>>>>         MemoryStream stream = new System.IO.MemoryStream();
>>>>>>         domDocument.Save(stream);
>>>>>>         Byte[] byteArray = stream.ToArray();
>>>>>>         string outerXml =
>>>>>> System.Text.Encoding.UTF8.GetString(byteArray,
>>>>>> 0,
>>>>>> byteArray.Length);
>>>>>>         byteArray = System.Text.Encoding.UTF8.GetBytes(outerXml);
>>>>>>         //Save the new layer definition to the Session.
>>>>>>         MgByteSource byteSource = new MgByteSource(byteArray ,
>>>>>> byteArray.Length);
>>>>>>         byteSource.SetMimeType(MgMimeType.Xml);
>>>>>>         MgResourceIdentifier resourseId = new
>>>>>> MgResourceIdentifier("Session:" + map.SessionId + "//" + layerName +
>>>>>> "." + MgResourceType.LayerDefinition);
>>>>>>         // Set the map with the new resource
>>>>>>         resourceSrvc.SetResource(resourseId, byteSource.GetReader(),
>>>>>> null);
>>>>>>         MgLayer newLayer = addLayerRsc2Map(resourseId, resourceSrvc,
>>>>>> layerName, layerLegendLabel, map);
>>>>>>         return newLayer;
>>>>>>     public void addLayer2Group(MgLayer layer, string layerGroupName,
>>>>>> string layerGroupLegendLabel, MgMap map)
>>>>>>     // Adds a layer to a layer group. If necessary, it creates
>>>>>>     // the layer group.
>>>>>>         //Get the layer group
>>>>>>         MgLayerGroup layerGroup;
>>>>>>         MgLayerGroupCollection layerGroupCollection =
>>>>>>         if( layerGroupCollection.Contains(layerGroupName) )
>>>>>>             layerGroup =
>>>>>> layerGroupCollection.GetItem(layerGroupName);
>>>>>>         else
>>>>>>             //It does not exist, so create it.
>>>>>>             layerGroup = new MgLayerGroup(layerGroupName);
>>>>>>             layerGroup.SetVisible(true);
>>>>>>             layerGroup.SetDisplayInLegend(true);
>>>>>>             layerGroup.SetLegendLabel(layerGroupLegendLabel);
>>>>>>             layerGroupCollection.Add(layerGroup);
>>>>>>         //Add the layer to the group.
>>>>>>         layer.SetGroup(layerGroup);
>>>>>>> Did you look at the buffer sample code in the AJAX viewer?
>>>>>>> It does exactly what is required, besides inserting your points.
>>>>>>> About your code:
>>>>>>> You do not use the "resourceIdentifier" variable, which means your
>>>>>>> layer might reference something else.
>>>>>>> You save the layers to the regular repository, which is fine, but
>>>>>>> each use will overwrite the previous copy, making it impossible to
>>>>>>> reliably serve more than one user.
>>>>>>> You do not add the layer to the runtime map, and you do not save the
>>>>>>> runtime map.
>>>>>>> You write: "I just want to display them".
>>>>>>> Well, MapGuide works by displaying data from a FeatureSource, styled
>>>>>>> through a LayerDefinition.
>>>>>>> You cannot insert data in the LayerDefinition, it must be in a
>>>>>>> FeatureSource.
>>>>>>> If you insert the data in an existing FeatureSource, with an
>>>>>>> existing
>>>>>>> layer, that is fine too, but I cannot guess that is what you want.
>>>>>>> You did not mention an Xml file with points before, just a single
>>>>>>> point.
>>>>>>> Depending on your data, you may want to insert them into a database
>>>>>>> (like Sqlite or Access), or into an SDF file.
>>>>>>> If you choose the database version, your FeatureSource can be of
>>>>>>> type
>>>>>>> ODBC.
>>>>>>> If you use a database, you can insert the points using regular SQL
>>>>>>> queries against the database.
>>>>>>> If the points are persistent (that is, not tied to a particular
>>>>>>> users
>>>>>>> map, like session values), you can just create a FeatureSource +
>>>>>>> Layer through Maestro or Studio without requirering any code.
>>>>>>> If you are looking to create something similar to "Points of
>>>>>>> interrest"
>>>>>>> with a nice little flag, you might
>>>>>>> consider using OpenLayers instead of the AJAX viewer:
>>>>>>> http://www.openlayers.org/
>>>>>>> http://www.openlayers.org/dev/examples/georss-markers.html
>>>>>>> (OpenLayers also supports MapGuide as the backend server)
>>>>>>> Galois skrev:
>>>>>>>> First of all, thank u fro your reply.
>>>>>>>> I don't get why should I create a temp layer.
>>>>>>>> I have some coordinates in an XML file, and I just want to display
>>>>>>>> them on an existing layer.
>>>>>>>> Though I tried to create a new layer, it does not appear in my maps
>>>>>>>> layers.
>>>>>>>> That's what I did...
>>>>>>>> MgResourceIdentifier resourceIdentifier = new
>>>>>>>> MgResourceIdentifier("Library://GoSpatial/Data/airports.FeatureSource");
>>>>>>>>         MgResourceIdentifier layerResId = new
>>>>>>>> MgResourceIdentifier("Library://GoSpatial/Layers/TmpLayer.LayerDefin
>>>>>>>> i
>>>>>>>> tion");
>>>>>>>>         string layerDefinition =
>>>>>>>> File.ReadAllText("C:/Inetpub/wwwroot/iwaygis/TmpLayer.LayerDefinitio
>>>>>>>> n
>>>>>>>> .xml");
>>>>>>>>         MgByteReader reader = new MgByteReader(layerDefinition,
>>>>>>>> "text/xml");
>>>>>>>>         resourceSrvc.SetResource(layerResId, reader, null);
>>>>>>>>         tmpLayer = new MgLayer(layerResId, resourceSrvc);
>>>>>>>>         tmpLayer.SetName("TempLayer");
>>>>>>>>         tmpLayer.SetLegendLabel("TempLayer");
>>>>>>>>         tmpLayer.SetDisplayInLegend(true);
>>>>>>>>         tmpLayer.SetSelectable(true);
>>>>>>>>         MgLayerCollection layers = map.GetLayers();
>>>>>>>>         layers.Insert(0, tmpLayer);
>>>>>>>>         tmpLayer.SetVisible(true);
>>>>>>>>         tmpLayer.ForceRefresh();
>>>>>>>> Thx!
>>>>>>>>> A few steps are involved:
>>>>>>>>> 1. Create a temporary featuresource 2. Create a temporary layer to
>>>>>>>>> display the features 3. Insert the temporary layer into the
>>>>>>>>> runtime
>>>>>>>>> map
>>>>>>>>> The buffer files in the MapGuide viewer has template code for all
>>>>>>>>> three steps.
>>>>>>>>> All steps are explained in the Developer Guide (PDF version at
>>>>>>>>> least).
>>>>>>>>> You might also want to look here:
>>>>>>>>> http://trac.osgeo.org/mapguide/wiki/CodeSamples/ASP.Net/ScribbleApp
>>>>>>>>> Galois skrev:
>>>>>>>>>> Hello,
>>>>>>>>>> I´m trying to add a point to a map but I have no idea how to it.
>>>>>>>>>> I have declare the map object, and also I create a point with
>>>>>>>>>> it's
>>>>>>>>>> coordinates.
>>>>>>>>>> But I don't know what is the next step that I have to do...
>>>>>>>>>> The code follows....
>>>>>>>>>> public partial class _Default : System.Web.UI.Page {
>>>>>>>>>>     public string sessionId;
>>>>>>>>>>     public string webLayout;
>>>>>>>>>>     protected void Page_Load(object sender, EventArgs e)
>>>>>>>>>>         string physicalPath = @"C:\Program
>>>>>>>>>> Files\MapGuideOpenSource\WebServerExtensions\www\webconfig.ini";
>>>>>>>>>>         try
>>>>>>>>>>             MapGuideApi.MgInitializeWebTier(physicalPath);
>>>>>>>>>>             passAndSession();
>>>>>>>>>>             //Associate a session ID with the MgSiteConnection
>>>>>>>>>> Object
>>>>>>>>>>             MgUserInformation userInfo_new = new
>>>>>>>>>> MgUserInformation(sessionId);
>>>>>>>>>>             MgSiteConnection siteConnection = new
>>>>>>>>>> MgSiteConnection();
>>>>>>>>>>             siteConnection.Open(userInfo_new);
>>>>>>>>>>             MgResourceService resourceSrvc =
>>>>>>>>>> (MgResourceService)siteConnection.CreateService(MgServiceType.Reso
>>>>>>>>>> u
>>>>>>>>>> rceService);
>>>>>>>>>>             MgMap map = new MgMap(siteConnection);
>>>>>>>>>>             webLayout =
>>>>>>>>>> "Library://GoSpatial/Web+Layouts/Autostrada+Brescia+Padova+Map.Web
>>>>>>>>>> L
>>>>>>>>>> ayout";
>>>>>>>>>>             MgResourceIdentifier resId = new
>>>>>>>>>> MgResourceIdentifier("Library://GoSpatial/Maps/Italy
>>>>>>>>>> Map.MapDefinition");
>>>>>>>>>>             String mapName = resId.GetName();
>>>>>>>>>>             MgResourceIdentifier mapStateId = new
>>>>>>>>>> MgResourceIdentifier("Session:" + sessionId + "//" + mapName +
>>>>>>>>>> + MgResourceType.Map);
>>>>>>>>>>             map.Create(resourceSrvc, resId, mapName);
>>>>>>>>>>             map.Save(resourceSrvc, mapStateId);
>>>>>>>>>>             map.Open(resourceSrvc, mapName);
>>>>>>>>>>             createPoint();
>>>>>>>>>>         catch (Exception ex)
>>>>>>>>>>             throw (ex);
>>>>>>>>>>     public string passAndSession()
>>>>>>>>>>         MgUserInformation userInfo = new
>>>>>>>>>> MgUserInformation("Administrator",
>>>>>>>>>> "admin");
>>>>>>>>>>         MgSite site = new MgSite();
>>>>>>>>>>         site.Open(userInfo);
>>>>>>>>>>         sessionId = site.CreateSession();
>>>>>>>>>>         return sessionId;
>>>>>>>>>>     public MgPoint createPoint()
>>>>>>>>>>         MgGeometryFactory geometryFactory = new
>>>>>>>>>> MgGeometryFactory();
>>>>>>>>>>         MgCoordinateXY coordinate = (MgCoordinateXY)
>>>>>>>>>> geometryFactory.CreateCoordinateXY(10.913161, 45.408046);
>>>>>>>>>>         MgPoint point = geometryFactory.CreatePoint(coordinate);
>>>>>>>>>>         return point;
>>>>>>>>> _______________________________________________
>>>>>>>>> mapguide-users mailing list
>>>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>>>>> View this message in context:
>>>>>> http://www.nabble.com/Adding-a-point-to-a-map...-PLZ-Help%21%21%21-%28
>>>>>> .NET--
>>>>>> -C-%29-tp19954532p19994399.html
>>>>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>>>>> __________ Information from ESET NOD32 Antivirus, version of virus
>>>>>> signature database 3523 (20081015) __________
>>>>>> The message was checked by ESET NOD32 Antivirus.
>>>>>> http://www.eset.com
>>>>> http://www.nabble.com/Adding-a-point-to-a-map...-PLZ-Help%21%21%21-%28.NET--
>>>>> -C-%29-tp19954532p19994711.html
>>>>> signature
>>>>> http://www.eset.com
View this message in context: http://www.nabble.com/Adding-a-point-to-a-map...-PLZ-Help%21%21%21-%28.NET---C-%29-tp19954532p20010502.html
