[mapguide-users] Generate map tiles from Oracle data
Jason Birch
Jason.Birch at nanaimo.ca
Thu Oct 16 11:24:52 EDT 2008
Unfortunately, no. In my opinion, this is a design flaw in MapGuide;
base layer groups should be their own entity that is "included" in other
maps. Currently, you can not share them, and any changes in the dynamic
map invalidates the layer cache.
If you are using OpenLayers directly, rather than Fusion or the Ajax
viewer, I think you can work around this by including two MapGuide maps,
one tiled and one untiled. My hope is that a future version of Fusion
(2.0?) will allow you to do this as well.
Jason
-----Original Message-----
Subject: Re: [mapguide-users] Generate map tiles from Oracle data
My next question is whether MapGuide will use the same set of tiles for
base
layers that are referenced in several different map definitions. I
assume it
will... can somebody confirm this?
