[mapguide-users] Please help! Has anybody used
King.Oracleinrealconditions?
FISHeR1
fisher at smtp.ru
Fri Oct 17 03:23:07 EDT 2008
Haris Kurtagic wrote:
> Hi,
> I was not able to reproduce problem with my builds of MapGuide 2.0.1 and
> King.Oracle, at least not yet.
> However, I was able to reproduce memory problem with standard
> installation files from MG 2.0.1 and King.Oracle binaries from our web
> site and Oracle instant client 10.2.0.3. Also I noticed that layer is
> rendered very very slowly.
> I tried with Fdo2Fdo to read same data from Oracle (and schema creation)
> and it looks to me as fast as it is supposed to be.
> Also I can't see any memory issues.
> If you can test your data and memory issues with Fdo2Fdo that could
> help.
> I will look more into this.
> Thanks,
> Haris
that is real, there is no leak by working with fdo2fdo (0.7.6). But that is
strange. Everything is OK by addressing to views with 2000 objects. When I
make request to the single chart (16000 objects), fdo2fdo is damaged.
It likes that the real leaks appear only by working with MapGuide.
About versions, which I use, I wrote here:
http://www.nabble.com/King.Oracle-0.7.3-(0.7.4)-Memory-Leak-with-MGOS-2.0-(2.0.1,-2.0.2)-tt19690045.html
View this message in context: http://n2.nabble.com/Please-help%21-Has-anybody-used-King.Oracle-in-real-conditions--tp1140937p1344215.html
