[mapguide-users] New to MapGuide OS
Nelson Soto
NSoto at plotplans.com
Fri Oct 17 10:16:07 EDT 2008
Indeed, I just recognized this! Thanks for the prompt responses!
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Kenneth Skovhede, GEOGRAF A/S
Sent: Friday, October 17, 2008 10:11 AM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] New to MapGuide OS
You are most likely using IE, which has renamed the Sheboygan.mgp file til Sheboygan.zip.
Rename it back, and you can load it.
Regards, Kenneth Skovhede, GEOGRAF A/S
Nelson Soto skrev:
Ok, so at the risk of sounding a bit naïve, I am at the point where I have dropped the Sheboygan Sample Data in the folder "Packages" in the Server install directory. When logged into the Admin Site however, it does not list any packages as being present to load.
I am using IIS 5.1, which I have read may pose issues down the line with a maximum connection limit (although I think I can circumvent that...).
The package path in the configuration is 'C:/Program Files/MapGuideOpenSource2.0/Server/Packages/' which is the correct path. Has anyone ever run into a similar situation?
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Nelson Soto
Sent: Friday, October 17, 2008 9:58 AM
Subject: RE: [mapguide-users] New to MapGuide OS
This was not what I had looked at, I think I was looking throught the dev PDF. This is exactly what I was looking for I believe. Thank you!
Sent: Friday, October 17, 2008 9:54 AM
Was one of the PDF's the "Gettings Started with MapGuide":
http://mapguide.osgeo.org/2.0/documentation.html
If so, which of the five steps on page 1 is causing you trouble?
Nelson Soto skrev:
Hello all,
I have experience with MapServer but just discovered MapGuide as a seeming alternative... I would like to get the samples running but I am quite clueless. I am attempting to read the PDF help but it doesn't seem to help me get the demo's up and running or I am kind of an imbecile. Can anyone guide me to a tutorial or instructions on how to set up the samples, I guess Sheboygan?
Thanks,
Nelson
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20081017/9560e3f1/attachment.html
