[mapguide-users] New to MapGuide OS
Nelson Soto NSoto at plotplans.com
Fri Oct 17 10:58:59 EDT 2008
The site I'm trying to view is the dotnetviewer? So, isn't this folder the same folder?
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Berdel, Brian
Sent: Friday, October 17, 2008 10:26 AM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] New to MapGuide OS
You need to copy the dll's from the mapviewernet bin directory to the bin directory of your site.
Brian
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Nelson Soto
Sent: Friday, October 17, 2008 10:23 AM
I am having a .NET related error when trying to load the .NET ajax viewer sample...
It is a rudimentary error. I can not load the namespace OSGeo.MapGuide. Does this mean I need to reinstall MapGuide or have I missed an additional step? I believe I installed both MapGuide and WebServerExtensions and am also under the impression I selected the .NET part of the configuration during install..
Sent: Friday, October 17, 2008 10:16 AM
Indeed, I just recognized this! Thanks for the prompt responses!
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Kenneth Skovhede, GEOGRAF A/S
Sent: Friday, October 17, 2008 10:11 AM
Subject: Re: [mapguide-users] New to MapGuide OS
You are most likely using IE, which has renamed the Sheboygan.mgp file til Sheboygan.zip.
Rename it back, and you can load it.
Regards, Kenneth Skovhede, GEOGRAF A/S
Nelson Soto skrev:
Ok, so at the risk of sounding a bit naïve, I am at the point where I have dropped the Sheboygan Sample Data in the folder "Packages" in the Server install directory. When logged into the Admin Site however, it does not list any packages as being present to load.
I am using IIS 5.1, which I have read may pose issues down the line with a maximum connection limit (although I think I can circumvent that...).
The package path in the configuration is 'C:/Program Files/MapGuideOpenSource2.0/Server/Packages/' which is the correct path. Has anyone ever run into a similar situation?
Sent: Friday, October 17, 2008 9:58 AM
This was not what I had looked at, I think I was looking throught the dev PDF. This is exactly what I was looking for I believe. Thank you!
Sent: Friday, October 17, 2008 9:54 AM
Was one of the PDF's the "Gettings Started with MapGuide":
http://mapguide.osgeo.org/2.0/documentation.html
If so, which of the five steps on page 1 is causing you trouble?
Nelson Soto skrev:
Hello all,
I have experience with MapServer but just discovered MapGuide as a seeming alternative... I would like to get the samples running but I am quite clueless. I am attempting to read the PDF help but it doesn't seem to help me get the demo's up and running or I am kind of an imbecile. Can anyone guide me to a tutorial or instructions on how to set up the samples, I guess Sheboygan?
Thanks,
Nelson
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20081017/84700c8e/attachment.html
