Re[mapguide-users] nderingService on MGOS 2.0.2
Alex Fordyce afordyce at ix.netcom.com
Fri Oct 17 11:49:02 EDT 2008
Well, I don't know if it's a "real" bug. The Developers Guide shows the
parameters as uCase as does the Server API doc. Maybe a mention of this in
the dev guide would help some people (it is the only parameter that is case
sensitive). Of course I'll never do that again, but it may save someone else
from a mild headache.  My feeling is that it doesn't really need to be
logged as a bug.
zspitzer wrote:
> there's a few case sensitive gotcha's like that with mapguide...
> worth filing a bug?
> On Fri, Oct 17, 2008 at 11:41 AM, Alex Fordyce <afordyce at ix.netcom.com>
> wrote:
>> Kenneth,
>> I don't know whether to laugh or cry, but that was it! Changed "png" to
>> "PNG" and it works great now.
>> Thank you so much.
>> Regards,
>> alex
>> Kenneth Skovhede, GEOGRAF A/S wrote:
>>> I use the GETMAPIMAGE function extensively, which I belive is the same
>>> function, and it works great.
>>> What line causes the error?
>>> Have you tried with "PNG" instead of "png"?
>>> Regards, Kenneth Skovhede, GEOGRAF A/S
>>> Alex Fordyce skrev:
>>>> Has anyone been successful using the RenderingService using release
>>>> 2.0.2? It
>>>> does not seem to be working for me. My install is MGOS 2.0.2 ,.NET, and
>>>> IIS.
>>>> I am trying to save a map as a PNG to my local drive.
>>>> I get the following error: "An unclassified exception occurred." and no
>>>> file
>>>> is created. Yes, c:\temp exists. :)
>>>> Sample C# code:
>>>> MgByteReader byteReader = renderingService.RenderMap(map, selection,
>>>> mapExtent, 650, 650, bgcolor, "png" );
>>>> MgByteSink byteSink = new MgByteSink(byteReader);
>>>> string fileName = "c:\\temp\\myMap.png";
>>>> byteSink.ToFile(fileName);
>>>> Any suggestions or success stories would be welcomed.
>>>> thanks.
>>>> alex
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> View this message in context:
>> http://www.nabble.com/RenderingService-on-MGOS-2.0.2-tp20005723p20023938.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
> Zac Spitzer -
> http://zacster.blogspot.com (My Blog)
> +61 405 847 168
View this message in context: http://www.nabble.com/RenderingService-on-MGOS-2.0.2-tp20005723p20035930.html
