[mapguide-users] Supported WMS and WFS in MapGuide
gom
gord.mckenzie at canam.com
Fri Oct 17 13:13:17 EDT 2008
To go with my last message, I should have said that the data is in Southern
Alberta. The wms was created to try using the data in Google Earth so I do
the wms in EPSG:4326 and the EPSG:26912 is the code for the original data
which is in UTM Zone 12N.
gom wrote:
> I can succesfully use wms in ArcMAP 9.3, from Mapguide 1.2.
> These are my WMS layer seettings in Mapguide.
> Bounds
> <BOUNDS SRS="EPSG:4326" west="-114" south="49" east="-110" north="50" />
> Other SRS
> EPSG:26912
> This is what I have as my wms string in ArcMAP
> http://myserver.com/mapguide/mapagent/mapagent.fcgi?
> Alex Fordyce wrote:
>> Via WMS I've tried to serve the Sheboygan sample data to ArcGIS 9.2 and
>> haven't really been successful yet. I'm using mgos 2.0.2 and both mgos
>> and
>> arcgis are on the same internal domain.
>> ArcGIS sees my mg WMS server and pulls the layers over. However, the
>> layers
>> do not display.
>> The documentation for both MG and ArcGIS claim to support OGC:WMS 1.1.1
>> Has anyone been successful using this configuration? Any ideas?
>> thanks,
>> alex
>> zspitzer wrote:
>>> I think you can test the server side capabilities using the web tier
>>> tests
>>> which allows passing a version
>>> http://locahost:8008/mapguide/mapagent/
>>> there are a few quirks with WMS in there, GetMap returns only layers (
>>> and a list of them )
>>> rather than maps, there's no caching and or http cache semantics either
>>> this document gives a nice nice overview of WMS support tho
>>> http://feeds.autodesk.com/servlet/JiveServlet/download/233-594160-5688489-163673/ConfiguringAWMSFeatureSource.doc
>>> On Fri, Oct 17, 2008 at 7:12 AM, BradM <masonb at dfo-mpo.gc.ca> wrote:
>>>> WMS is critical to the success of my mapguide applications. Can
>>>> anyone
>>>> answer Kenneth?
>>>> Kenneth Skovhede, GEOGRAF A/S wrote:
>>>>> If found the following document describing the versions of WMS and WFS
>>>>> supported in MapGuide:
>>>>> http://mapguide.osgeo.org/faq_ogcserices.html
>>>>> The page appears quite outdated: "as soon as the FDO providers for WMS
>>>>> and WFS are available".
>>>>> The above mentioned page is not making a clear distinciton between
>>>>> being
>>>>> a client and being a server.
>>>>> There was no apparent mentioning of WMS/WFS versions on the FDO
>>>>> website
>>>>> either.
>>>>> My questions are:
>>>>> 1. What versions are supported when MapGuide is a WMS/WFS server?
>>>>> 2. What versions are supported when MapGuide is a WMS/WFS client?
>>>>> 3. Does MapGuide support WFS-T as a server?
>>>>> 4. Does MapGuide support WFS-T as a client?
>>>>> 5. How are the OGC certifications for server/client WMS/WFS coming
>>>>> along?
>>>>> Regards, Kenneth Skovhede, GEOGRAF A/S
>>>>> _______________________________________________
>>>>> mapguide-users mailing list
>>>>> mapguide-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>>> View this message in context:
>>>> http://www.nabble.com/Supported-WMS-and-WFS-in-MapGuide-tp19968309p20016664.html
>>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>> Zac Spitzer -
>>> http://zacster.blogspot.com (My Blog)
>>> +61 405 847 168
>> http://www.nabble.com/Supported-WMS-and-WFS-in-MapGuide-tp19968309p20037000.html
View this message in context: http://n2.nabble.com/Supported-WMS-and-WFS-in-MapGuide-tp1331826p1346103.html
