[mapguide-users] Please help! Has anybody usedKing.Oracleinreal
conditions?
djonio
djonio at miami-airport.com
Mon Oct 20 04:40:47 EDT 2008
Haris, et.al.
It certainly looks to me that you are on the right track here.
It is an established fact that the .NET(managed) connection object in
10.2.0.3 does not behave properly. (See Oracles OTN forum on .NET) The issue
in .NET is the connection "Pool".
To be brief the issue in .NET:
With "Pool" set to false:
a) the connection object never times-out, never dies. In addition, and even
though a newly created objects "signature" is identical, a new connection
gets created. It looks like, in real life, Pool=false means: always create a
new connection object and keep it around until the instantiating process
dies. The work around here is to keep track of the connection object and
just keep using this one. Yes, FDO2FDO “appears” to exhibit this same
behavior.
With "Pool" set to true:
a)it appears user defined types(UDT's), which sdo_geometry is on the client
side, if not resolved with the first invocation of this particular
connection object will NOT resolve later on. This appears to be an issue
with the connection objects cache storage. The work around here to set
“Pool=false”!!! GOTCH’A
All of this becomes evident, at least in my case, when working with tables
of 100,000+ rows with applications totally unrelated to FDO.
All that being said, IMHO the issue is Oracle Clients not behaving as
advertised. If there is/are issues with the FDO provider it will be
impossible to discover until it is discovered which Oracle client actually
works correctly.
r,
dennis
View this message in context: http://www.nabble.com/Please-help%21-Has-anybody-used-King.Oracle-in-real-conditions--tp19793029p20065401.html
