[mapguide-users] Mapguide Installation
JeffJensen jefferyjjensen at gmail.com
Tue Oct 21 12:00:22 EDT 2008
Hello Padmini,
I had similar errors, that is unable to login to the MapGuide Site
Administrator and I put together some notes on
http://faculty.unlv.edu/jensen/html/MapGuide/#MGUninstall installing and
uninstalling MapGuide  which solved the problem on my end. It might help
you.
Regards,
Jeff Jensen
padmini godavarthi wrote:
> Hi,
> Iam Trying to Install the Mapguide opensource 2.0.
> I followed the pdf,
> http://mapguide.osgeo.org/sites/mapguide.osgeo.org/files/GettingStarted.pdf
> But i got an error at  4 Point.
> We loaded the data and  typed the url given in pdf(4. Load the sample data
> using the Site Administrator application.
> Open a web browser to the following URL:
> http://localhost:8008/mapguide/mapadmin/login.php.
> Login using the user id "Administrator" and the default password "admin".
> When you see the
> Manage Servers page appear, select "Load Packages" in the left navigation
> bar. Select the radio
> button next to Sheboygan.mgp and click "Load Package").
> When i logged in to the application(Username : Administrator and Password
> : admin),it seems an error that
> (HTTP 500 Internal Server Error)
> The website cannot display the page
>    Most likely causes:
> The website is under maintenance.
> The website has a programming error.
>    What you can try:
>      Refresh the page.
>      Go back to the previous page.
>      More information
> This error (HTTP 500 Internal Server Error) means that the website you are
> visiting had a server problem which prevented the webpage from displaying.
> If anybody Knows this Problem Plz Help me
> Thanks and Regards,
> Padmini.
View this message in context: http://www.nabble.com/Mapguide-Installation-tp20091313p20093592.html
