[mapguide-users] error 1053
Nandorov nandorov at gmail.com
Tue Oct 21 15:33:00 EDT 2008
thanks dave for ur answer.
i run the mgserver2009.exe from cmd and i got the following error code
"0xc0000005".
Dave Wilson-3 wrote:
> The mapguide service will fail to start if your system is slow at starting
> other services. Often times defragging your c drive will speed your boot
> process and allow these services to start as expected on a reboot.
> In this case you problem may be something else.
> Can you try running the mgserver2009.exe from a command line with the /run
> parameter and see if you get an error.
> Dave
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Nandorov
> Sent: Tuesday, October 21, 2008 11:46 AM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] error 1053
> hi,
> i have a problem with my mapguide service. it's down and when i'm trying
> to
> start the service i get the following error "error 1053:the service did
> not
> respond to the start or control request in a timely fashion".
> i'm using windows xp sp 2
> how can i fix it?
> thanks
> http://www.nabble.com/error-1053-tp20095659p20095659.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
View this message in context: http://www.nabble.com/error-1053-tp20095659p20097803.html
