[mapguide-users] Error openning a map
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Thu Oct 23 05:07:05 EDT 2008
Yes, you are running the code before the viewer has started.
You cannot use the runtime map before the viewer has started, and thus
created the map.
Regards, Kenneth Skovhede, GEOGRAF A/S
Iñigo Mazo skrev:
> Thank you Kenneth, I did you told me and now I have another problem.
> This is my code now:
> map.Open(resService, "Sheboygan");
> In this line returns this mistake: " {"Resource was not found:
> Session:16634852-0000-1000-8000-005056c00008_en_7F0000010AFC0AFB0AFA//Sheboygan.Map"}"
> Do you know what the problem is?
> Thank you
> *De:* mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] *En nombre de *Kenneth
> *Enviado el:* jueves, 23 de octubre de 2008 9:21
> *Para:* MapGuide Users Mail List
> *Asunto:* Re: [mapguide-users] Error openning a map
> That is one misleading message :).
> In line 2+3, connect, but you have no session.
> So, you cannot read anything from the session repository.
> This means the sessionid string (internal) is empty, which is the
> exception you get.
> If you want to read the runtime map, you must open the connection with
> the session ID,
> not with a username/password (line 2+3).
> Iñigo Mazo skrev:
> <http://www.avalon.com.es>
> *AVALON Tecnologías de la Información, S.L.*
> *Generamos /Ideas/, Construimos /Soluciones/*
> *http://www.avalon.com.es*
> *C/ Gran Vía 81, 8ª Planta Bilbao 48011 Teléfono: (+34) 94 441 51 40
> Fax: (+34) 94 441 51 92 *
> Hello,
> We have a problem openning a map with MapGuide Studio 2009. Our code
> is this:
> MgSiteConnection siteConnection = new MgSiteConnection();
> MgUserInformation userInfo = new
> MgUserInformation("Anonymous", "");
> siteConnection.Open(userInfo);
> MgResourceService resService =
> (MgResourceService)siteConnection.CreateService(MgServiceType.ResourceService);
> MgFeatureService featureService =
> (MgFeatureService)siteConnection.CreateService(MgServiceType.FeatureService);
> MgMap map = new MgMap();
> In this line returns this mistake: " {"Invalid argument(s):\n\t[0] =
> \" \"\nThe string cannot be empty."} "
> Thank you.
> *Iñigo Mazo González
> imazo at avalon.com.es <mailto:imazo at avalon.com.es>
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org <mailto:mapguide-users at lists.osgeo.org>
Skipped content of type multipart/related
