[mapguide-users] Edit polygon
Dragan Podvezanec dragan.podvezanec at gmail.com
Fri Oct 24 07:30:07 EDT 2008
Hi.
Imho,
It's not too hard to add Drawing functionality, since API supports it.
Adding point,line and polygon to map and storing it into spatial database is
easy through DigitizePoint, DigitizePolygon and DigitizeLine. If you wish, I
can send you sample code.
But, editing is something totally different. You would have to add functions
like snapping, checking the topology, and moving polygons.
View this message in context: http://www.nabble.com/Edit-polygon-tp20123089p20148423.html
