Re[mapguide-users] project Raster
Don MacGregor sir_sunkee at yahoo.ca
Fri Oct 24 11:08:17 EDT 2008
Frank,
I find the link you sent very useful. I am not sure about the EPSG code of
10TM projection (NAD_1983_10TM_AEP_Resource) but the rest of the parameters
are,
PROJCS["NAD_1983_10TM_AEP_Resource",GEOGCS["GCS_North_American_1983",
DATUM["D_North_American_1983",
SPHEROID["GRS_1980",6378137.0,298.257222101]],
PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],
PROJECTION["Transverse_Mercator"],PARAMETER["False_Easting",0.0],
PARAMETER["False_Northing",0.0],PARAMETER["Central_Meridian",-115.0],
PARAMETER["Scale_Factor",0.9992],PARAMETER["Latitude_Of_Origin",0.0],
UNIT["Meter",1.0]]
Thanks
Frank Warmerdam-2 wrote:
> Don C. MacGregor wrote:
>> Hi folks,
>> I was wondering if any of you guys could help me out as I need to
>> re-project couple of hundred rasters from UTM to 10TM projection and I
>> am not sure about any automatic way to do that (GDAL ??). Any help in
>> this regard would be highly appreciated.
> Don,
> You may find the gdalwarp program appropriate.
>    http://www.gdal.org/gdalwarp.html
> I'm not familiar with the 10TM projection.  Is there an associated EPSG
> code?  Is it just UTM 10?
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Programmer for Rent
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/Reproject-Raster-tp20140169p20151914.html
