[mapguide-users] Cyrillic alphabet/Encoding problem
Stefan Dalakov s.dalakov at mapware.net
Fri Oct 24 12:57:42 EDT 2008
Nisha,
would you please clarify - is it me you are asking or milko_velichkov.
In the link I attached, it is the ajaxviewer, and it is a map created
with MapGuide Studio. If you are interested in more details, please send
me an email directly or start another thread in order not to spam
milko_velichkov's question about the encoding.
Stefan Dalakov
Nisha P wrote:
> is it use ajaxviewer or dwfviewer?if it is ajaxviewer then how can i
> get that type of map in the interface??
> On Fri, Oct 24, 2008 at 11:59 AM, Stefan Dalakov
> <s.dalakov at mapware.net <mailto:s.dalakov at mapware.net>> wrote:
>     I would suggest that the data in the SHP file is encoded using the
>     so-called DOS-cyrillic code page. I do not remember now the exact
>     code-page name, but I can come back to this later. At least this
>     works in my case.
>     Have a look at http://www.bgmapguide.com/mapguide/rila/rila.php ,
>     it is using mgos 1.2 but I don't think this makes any difference.
>     Stefan Dalakov
>     milko_velichkov wrote:
>         Unfortunately that's doesn't work in my case :(
>         http://www.nabble.com/file/p20144623/t.jpeg
>         Traian Stanev wrote:
>             Yes, SHP files and encodings is trouble... You can try to
>             force the
>             encoding to UTF-8 by adding a .CPG file alongside your SHP
>             file (with the
>             same filename as the .SHP). The contents should be a
>             single line of text,
>             saying "UTF-8", without the quotes. This will hint the FDO
>             provider for
>             SHP files to use that encoding. No guarantee that would
>             fix it though...
>             Another thing you can do to identify the cause of the
>             problem is try to
>             use a constant Cyrillic string as a label for your
>             geometry. If that shows
>             up fine in MapGuide, then the problem is upstream (in the
>             FDO provider),
>             otherwise it's a problem in the MapGuide code.
>             Traian
>                 -----Original Message-----
>                 From: mapguide-users-bounces at lists.osgeo.org
>                 <mailto:mapguide-users-bounces at lists.osgeo.org>
>                 [mailto:mapguide-users- <mailto:mapguide-users->
>                 <mailto:bounces at lists.osgeo.org>] On Behalf Of
>                 milko_velichkov
>                 Sent: Thursday, October 23, 2008 1:32 AM
>                 To: mapguide-users at lists.osgeo.org
>                 <mailto:mapguide-users at lists.osgeo.org>
>                 Subject: RE: [mapguide-users] Cyrillic
>                 Under "Selection" tab, when I have attribute
>                 information in Cyrillic
>                 from a
>                 SHP data source, they appear like маймуница :). Same
>                 with all labels
>                 within
>                 the Map window. Encoding used by default is UTF-8 (I
>                 don't have an idea
>                 how
>                 to change it within the MapGuide environment).
>                 Milko
>                     What exactly is the problem you are seeing? Also,
>                     are you using
>                 Unicode or
>                     some other encoding for the Cyrillic in your data
>                     source?
>                     Traian
>                         milko_velichkov
>                         Sent: Wednesday, October 22, 2008 4:26 AM
>                         Subject: [mapguide-users] Cyrillic
>                         Hi,
>                         Did anyone else has a problem with the
>                         visualization/encoding of
>                         Cyrillic
>                         letters when selecting features from within
>                         MapGuide?
>                         View this message in context:
>                         http://www.nabble.com/Cyrillic-
>                 alphabet-
>                         Encoding-problem-tp20104783p20104783.html
>                         Sent from the MapGuide Users mailing list
>                         archive at Nabble.com.
>                         _______________________________________________
>                         mapguide-users mailing list
>                         http://lists.osgeo.org/mailman/listinfo/mapguide-users
>                 http://www.nabble.com/Cyrillic-alphabet-
>                 Encoding-problem-tp20104783p20124621.html
>                 Sent from the MapGuide Users mailing list archive at
>                 Nabble.com.
>     mapguide-users at lists.osgeo.org <mailto:mapguide-users at lists.osgeo.org>
