Re[mapguide-users] project Raster
Don MacGregor sir_sunkee at yahoo.ca
Fri Oct 24 18:54:48 EDT 2008
Wow!! worked like a charm.
Thanks Frank!!
Frank Warmerdam-2 wrote:
> Don MacGregor wrote:
>> Many thanks Frank for your prompt reply,
>> I am getting an error while running the following command using FWTools
>> Shell;
>> gdalwarp -t_srs '+proj=tmerc +lon_0=-115 +k=0.9992 +datum=NAD83'
>> raw_spot.tif utm11.tif
>> (while raw_spot.tif file in my bin folder)
>> ERROR 1: Translating source or target SRS failed:
>> '+proj=tmerc
> Don,
> On windows you should use double quotes around the coordinate system.
> Try:
> gdalwarp -t_srs "+proj=tmerc +lon_0=-115 +k=0.9992 +datum=NAD83"
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Programmer for Rent
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/Reproject-Raster-tp20140169p20159078.html
