[mapguide-users] Maestro API: RuntimeMapLayer.Selectable can't be
changed
carls
carlshe at 163.com
Sun Oct 26 11:31:21 EDT 2008
I want to add a runtimemaplayer to a runtime map, and write follow code.
ResourceIdentifier ri =
CloneLayerDefinitionForSession(LayerPath, AsLayerName, SessionID);
RuntimeMapLayer rtl = new RuntimeMapLayer(ParentMap);
rtl.ResourceId = ri.ToString();
rtl.Visible = true;
rtl.LegendLabel = AsLayerName;
rtl.NeedRefresh = true;
rtl.Selectable = true;
if (ParentMap != null)
AddRuntimeMapLayerToRuntimeMap(ParentMap, rtl);
return rtl;
The runtimemaplayer refers to a sql 2008 data source.
The bold line of above code can't be executed, the full message is :
[WebException: ...: (559) MgInvalidRepositoryTypeException。]
System.Net.WebClient.OpenRead(Uri address) +366
System.Net.WebClient.OpenRead(String address) +29
OSGeo.MapGuide.MaestroAPI.HttpServerConnection.OpenRead(String req) in
E:\Temp\Maestro\MaestroAPI\HttpServerConnection.cs:1078
[Exception: ...: (559) MgInvalidRepositoryTypeException。:
Invalid repository type.
Exception occurred in method MgResourceIdentifier.ParseIdentifier at line
420 in file
d:\buildforgeprojects\mapguide_open_source_v2.0\build_23.8\mgdev\common\platformbase\Services/ResourceIdentifier.cpp
E:\Temp\Maestro\MaestroAPI\HttpServerConnection.cs:1086
OSGeo.MapGuide.MaestroAPI.HttpServerConnection.GetResourceXmlData(String
resourceID) in E:\Temp\Maestro\MaestroAPI\HttpServerConnection.cs:299
OSGeo.MapGuide.MaestroAPI.ServerConnectionBase.GetResource(String
resourceID) in E:\Temp\Maestro\MaestroAPI\ServerConnectionBase.cs:380
OSGeo.MapGuide.MaestroAPI.ServerConnectionBase.GetFeatureSource(String
resourceID) in E:\Temp\Maestro\MaestroAPI\ServerConnectionBase.cs:357
OSGeo.MapGuide.MaestroAPI.RuntimeClasses.RuntimeMapLayer.FindResourceIDs(ServerConnectionI
con) in E:\Temp\Maestro\MaestroAPI\RuntimeClasses\RuntimeMap.cs:726
OSGeo.MapGuide.MaestroAPI.RuntimeClasses.RuntimeMapLayer.FindResourceIDs()
in E:\Temp\Maestro\MaestroAPI\RuntimeClasses\RuntimeMap.cs:752
OSGeo.MapGuide.MaestroAPI.RuntimeClasses.RuntimeMapLayer.set_Selectable(Boolean
value) in E:\Temp\Maestro\MaestroAPI\RuntimeClasses\RuntimeMap.cs:1039
Thanks for help!
Regards, Carl SHE
View this message in context: http://n2.nabble.com/Maestro-API%3A-RuntimeMapLayer.Selectable-can%27t-be-changed-tp1379205p1379205.html
