[mapguide-users] noob question about mapguide and java
Nandorov
nandorov at gmail.com
Mon Oct 27 16:00:26 EDT 2008
Thanks Jason.
the problem was in the httpd.conf of my apache. i have to add the java
references, because php is the default.
btw, have you tried build an app using struts with mapguide? or loading some
other jars to the app?
thanks
JasonBirch wrote:
> Check to make sure that the "mapguide2009" path actually exists. If
> you're using MGOS, I believe that this should just be "mapguide"
> Jason
> -----Original Message-----
> From: Nandorov
> Subject: Re: [mapguide-users] noob question about mapguide and java
> i get the following error, any ideas?
> http://www.nabble.com/file/p20156762/error.jpg
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/noob-question-about-mapguide-and-java-tp20153677p20195204.html
