[mapguide-users] Problem With WMS service Mapguide Vers 2.0x
Mauricio Villablanca
mgvillablanca at yahoo.com
Wed Oct 29 14:08:11 EDT 2008
You need to modify the properties of the layer definition. Right click on
your layer definition, select properties and enable the WMS for that layer.
Use the name of the layer for the title and set the bounds properly. For
example for a map that uses the CA83-VF coordinate system it would be:
<Bounds SRS="CA83-VF" west="6471530.955574" south="1852326.791050"
east="6474752.036316" north="1855496.580698"/>
Then when you send parameters to mapagent.fcgi, only use the layers that
have the WMS enabled.
glovera wrote:
> Dear all,
> I have a problem with the wms service, i can see the layer in the Mapguide
> studio, but if i publish my map the service not work. (the refresh the map
> is very quickly and don`t show de layer)
> Thank's.
View this message in context: http://www.nabble.com/Problem-With-WMS-service-Mapguide-Vers-2.0x-tp20232466p20232642.html
