[mapguide-users] Is it possible to publish a session layer as WMS ?
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Thu Oct 30 05:01:51 EDT 2008
You can request this by creating a ticket.
If you want to speed it along, you can create an RFC,
but that requires some serious work regarding the
eventual implementation. This in turn requires
a lot of knowledge about the MapGuide inner workings.
Another option is to fund someone to build it and submit it.
Regards, Kenneth Skovhede, GEOGRAF A/S
carls skrev:
> What I meant is whether it is possible to add a function to next version of
> MG OS for publishing a session-layer in WMS.
> Maybe MG OS team can have a new RFC about it.
>>> No. You have to save layers to the Library repository in order to access
>>> them via WMS. The reason for this is that the mapagent binary expects to
>>> find the layers there.
>>> Carl wrote:
>>>>  I now use MG OS + Openlayers to develop a WebGIS system.
>>>> I defined a basic map as base layer, and want to use a dynamic layer (
>>>> for
>>>> example, clone a existing layer and modify its filter).
>>>> Normally, it seems I should define a runtimemap wraping the cloned
>>>> layer.
>>>> Yes, I tried it. But with openlayers, if the mapguide layer is used as
>>>> overlayer, there will always be a 'access denied' message shown. I have
>>>> had
>>>> a post about the MapGuide overlayer with Openlayers.
>>>> (http://n2.nabble.com/Access-denied-for-MapGuide-Overlayer-%28with-patched-MapGuide.js%29-tt1307180.html#a1307180)
>>>> So I intend to use the Mapguide WMS. It seems MapGuide can only publish
>>>> a
>>>> predefined layer as WMS.
>>>> Thanks!
>>>> Regards, Carl SHE
>>>> View this message in context:
>>>> http://n2.nabble.com/Is-it-possible-to-publish-a-session-layer-as-WMS---tp1386781p1386781.html
>>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>>> _______________________________________________
>>>> mapguide-users mailing list
>>>> mapguide-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> http://www.nabble.com/Is-it-possible-to-publish-a-session-layer-as-WMS---tp20206768p20233889.html
> Regards, Carl SHE
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20081030/daab85af/attachment.html
