[mapguide-users] selectAggregate error
Rodolfo Moreno rmoreno at voxiva.com
Thu Oct 30 23:21:43 EDT 2008
done, ticket 745.
cheers
Jason Birch wrote:
> If you have a reproducible issue, I would strongly encourage you to file
> a ticket against it:
> http://trac.osgeo.org/mapguide/wiki/SubmitTicket
> Please ensure that you provide enough information and data for the
> developers to _easily_ reproduce the problem.  Preferably an MGP that
> contains all of the data and data/layer/map definitions they will
> require, along with external data in something like an Access database
> and the name of the ODBC connection being used.  If the problem requires
> a lot of work to reproduce, it is less likely to receive attention.
> Jason
> -----Original Message-----
> From: Rodolfo Moreno
> Subject: Re: [mapguide-users] selectAggregate error
> I have tested with different formats: unmanaged, managed shapes, managed
> sdf
> and unmanaged sql 2008 feature sources. As well I have tested in
> different
> viewers: Fusion and Ajax viewer. In all the cases the theming is wrong.
> Could it be registered as an issue?
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Rodolfo Moreno
CivilEng
View this message in context: http://n2.nabble.com/selectAggregate-error-tp1121116p1401726.html
