[mapguide-users] How to enable markup using Design review
    Andy Morsell
    amorsell at spatialgis.com
    Fri Sep  5 00:01:10 EDT 2008
I generally agree with the "give back if you take" mentality of open source
projects, especially this one.  But this particular problem lies at the core
of the DWF writer (eplot) which only Autodesk developers seem to be familiar
with.   And, the customers that I know of that have this problem all use
MapGuide Enterprise so it would seem that the complaint is valid.  Perhaps
the open source discussion list is not the correct place to voice this and
should instead be done on the Autodesk discussion groups.
By the way, this whole round-tripping problem has existed since the MapGuide
6 days where we could plot a map to DWF, but it had no spatial intelligence.
Andy
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
Sent: Thursday, September 04, 2008 5:48 PM
To: MapGuide Users Mail List
Subject: SPAM-LOW: Re: RE: [mapguide-users] How to enable markup using
Design review
Scott,
You know it's this an open source project, if you have customers who want
it, have you
considered putting some resources YOURSELF into fixing this problem on
behalf
of your customers?
z
On Fri, Sep 5, 2008 at 8:24 AM, Scott Hameister
<scotth at mpowerinnovations.com> wrote:
ANYBODY WORKING ON THIS OR IS THERE A FIX FOR THIS and Why is the ticket so
Old and of a low importance this is a huge functionality???
I utilized The EPLOT code to output a Mapguide AJAX map out to DWF using
mappingService.GeneratePlot and When I am able to mark the map up in Design
Review but unfortunately measure is useless as well as roundtriping back
into a DWG is useless NEITHER WORK...it obviously does not send out
georeferenced information as does map when you Plot...Another Oddball
occurunce it will publish data on only the topmost layer to have data
attributes and no others...Man This is SO CLOSE TO PERFECT FOR ROUND
TRIPPING DATA...PLease Someone Fix This...I have Customers Who desperately
hold their collective breaths for such a solution for once
JasonBirch wrote:
> Joel,
> I have an enhancement request for this item in the MapGuide Open Source
> Trac.  Can you please add your comments to this item?
> http://trac.osgeo.org/mapguide/ticket/144
> You may need to create an OSGeo UserID before editing this page, details
> are here:
> http://www.osgeo.org/osgeo_userid
> Thanks,
> Jason
> -----Original Message-----
> From: Joel Carranza
> Subject: [mapguide-users] RE: How to enable markup using Design review
> However, is there a way to generate a DWF out of the MapGuide which is
> more "geo-aware", which contains inside the DWF information about the
> map extent which the DWF covers, and where ADR can make use of tools
> like Measure and their geo-referencing ability?
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context:
http://www.nabble.com/How-to-enable-markup-using-Design-review-tp8598618p193
21268.html
Zac Spitzer -
http://zacster.blogspot.com (My Blog)
+61 405 847 168
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080904/3070f19b/attachment.html
