[mapguide-users] mgstudio 2009 Installation problem on vista
Rodolfo Moreno
rmoreno at voxiva.com
Sat Sep 6 14:30:53 EDT 2008
Hi Darrin,
I don't know exactly what vista version I have. I was find uot about it in
the web.
Accordingo to it I suppose that I have 32 bit version of vista.
Maybe is not possible to install in 32 bit version as well?
Darrin Maidlow wrote:
> Hi Rodolfo,
> Is your Vista machine running the 64 bit version of Vista? If so, you
> cannot install Studio on that machine. I tried changing the .ini file
> similar to what can be done with AutoCAD Map and Studio will install - but
> it crashes as soon as you run it. I've had to resort to a virtual machine
> running a 32 bit OS.
> darrin
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Rodolfo
> Moreno
> Sent: Friday, September 05, 2008 9:54 AM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] mgstudio 2009 Installation problem on vista
> Hi all,
> I am having a problem during the installation process.
> I have installed mgstudio 2009 trial version on window server 2003 sp2
> without problem, however when I tried to install on window vista I got an
> error message on the first time. In my second attemp the link showed up
> disabled, which is why I couldn't got the accurate error message.
> I will appreciate any suggestion.
> Rodolfo Moreno
> CivilEng
> http://n2.nabble.com/mgstudio-2009-Installation-problem-on-vista-tp841474p84
> 1474.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
Rodolfo Moreno
CivilEng
View this message in context: http://n2.nabble.com/mgstudio-2009-Installation-problem-on-vista-tp841474p948398.html
