[mapguide-users] Exception occurred in method
MgProxyFeatureReader.GetProperty
Jack Lee
jack.lee at autodesk.com
Tue Sep 9 15:04:41 EDT 2008
You should call IsNull to check if the value is not null before calling GetString.
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Rock Beans
Sent: Tuesday, September 09, 2008 2:57 PM
To: MapGuide Users Mail List
Subject: [mapguide-users] Exception occurred in method MgProxyFeatureReader.GetProperty
This error comes up in ASP.NET when random records, I guess contain
NULL entry. Why does it not just send a empty string? Is there a work
around for this?
featureReader.GetString("ADDR_NUM")
Value for ADDR_NUM property is null.Value for ADDR_NUM property is
null. Exception occurred in method MgProxyFeatureReader.GetProperty at
line 448 in file
d:\buildforgeprojects\carrera_nightly\build_32.2\ent\os\common\mapguidecommon\Services/ProxyFeatureReader.cpp
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
